Front brake reservoir relocation?
Old May 23, 2009 | 04:53 PM
chopfury's Avatar
chopfury
Default Front brake reservoir relocation?
Is there any way to relocate the front brake reservoir to get it off the handle bars? I notice a lot of custom choppers don't have this so was wondering how that is accomplished?
Old May 23, 2009 | 09:37 PM
CamFX's Avatar
CamFX
Well some if not alot of custom choppers have no front brake. If they do have a front brake, its sometimes hooked into the rear brake system and run through a proportioning valve. Sort of like a car system. Problem with that is if you get a leak, you have no brakes. One other system I have seen is the front brake is applied by rotating the throttle forward. I am not sure where the master cylinder is located because these systems are way to expensive for my taste so I have never checked them out thoroughly.
Old May 24, 2009 | 08:47 PM
chopfury's Avatar
chopfury
thanks for the info - that really surprises me that a lot of choppers don't use front brakes...that seems silly stupid to me.
Guess I was hoping there was some way to put that reservoir inside the handlebars MacGyver-style .
Old May 25, 2009 | 12:20 AM
CamFX's Avatar
CamFX
I am sure there is a way. I have seen many Bikes with oil in the frame instead of an oil tank. So putting brake fluid in the handlebars is possible with the right machine work.
Old Jun 8, 2009 | 08:21 PM
RE AND CHERYL's Avatar
RE AND CHERYL
The problem is the reservoir has to be above the master cylinder bore be cause it fed by gravity. Because of this it has to be above the bars.
Re'
Lonny Rae
May 26, 2017 11:59 AM
chevdude
Nov 11, 2012 09:36 AM
atrain68
Wheels/Tires
Apr 9, 2009 07:37 PM
WARG
Jul 13, 2008 04:04 PM
BigBearBiker
Jun 28, 2005 02:03 AM
