21" or 23" with single rotor
Old Oct 12, 2009 | 03:16 PM
catfish24's Avatar
catfish24
1st Gear
Default 21" or 23" with single rotor
Who's running a 21" or 23" with a single rotor? How does the braking performance change? I'd like to run a single rotor when I add the big wheel, it looks so much cleaner. Would I need to upgrade the front brake? Any info is appreciated.
Old Oct 12, 2009 | 03:56 PM
lkr0's Avatar
lkr0
you will probably have to go with a 6 piston with 13 inch rotor--check out hogpro, performance machine and jaybrake
Old Oct 12, 2009 | 04:15 PM
Hogpro's Avatar
Hogpro
Former Sponsor
We typically recommend going with a 13" left side brake caliper, 13" left front rotor, changing the brake line, and changing the master cylinder when you go from dual front brake to single. That combination gives you pretty good braking power and that nice clean look. Some guys have simply removed one brake caliper and kept their stock left caliper but the braking power is significantly reduced of you go that route.
Rob at Hogpro
cycler
Aug 8, 2018 12:26 AM
WiscoKid
Apr 28, 2014 03:53 PM
scuba1960
Sep 20, 2013 04:47 PM
Warpig
Aug 9, 2006 09:55 AM
slughill
May 26, 2006 04:28 PM
