Recommend tire
Old Aug 18, 2010 | 05:13 PM
empress16's Avatar
empress16
Stage II
Exclamation Recommend tire
I just bought a 2000 FLHT electra glide. It has stock Dunlaps on it now with spoked rims. What brand(s) should I consider replacing them with. I am not impressed with the Dunlaps.
I ride on Mt roads with lots of curves as well as the highway. So I want tires that are somewhat sticky.
All thoughts welcom as I am a newby to Harleys.....
Thanks
Old Aug 19, 2010 | 06:14 PM
tj316's Avatar
tj316
I have an 01 FLHTCI and run Avon Venom, they are softer than Dunlops and stick well, Metzlers are good as well
Old Aug 20, 2010 | 03:22 AM
grbrown's Avatar
grbrown
Another Avon fan here! Check on their website for the correct pressures if you buy them, because they use higher pressures than the stock Dunlops.
Old Aug 22, 2010 | 09:57 AM
KW-HD Rider's Avatar
KW-HD Rider
i find the Metzler's are better in the curves than the stock Dunlop's. It seems easier to lean and holds a line well. also better in rain grooves and bridge expansion joints which we have a lot of around here.
I got 10K out of the first 2 Dunlop's on my 08 Ultra. Only have 2K on the Metzler rear so I am not sure of tread life. From what I hear it is about the same.
Old Aug 27, 2010 | 06:10 AM
LozoB's Avatar
LozoB
Metzler Me880's or Avon Venom
Dynam1te
Nov 1, 2013 12:44 PM
trackadaptor
Sep 4, 2011 08:46 PM
zeus33
May 14, 2011 07:55 PM
Drail
Aug 27, 2009 03:32 AM
mile high king
May 16, 2009 09:52 AM
