rear tire leak
Old Feb 8, 2011 | 05:44 PM
shuggy's Avatar
shuggy
Default rear tire leak
Here's my question,I replaced my tires last fall; no problems getting the tires on or off;or balanced,I have all the tools to do the job,my problem is my rear tire has a slow leak where the tire meets the rim (bead)I noticed it last fall while washing the wheel,the soap started bubbling all around the rim,is there any way to stop that,like something I could put on the rim or tire ,when I mounted the tire on, I did not put anything on like some sort of glue or anthing like that,should I have??? thanks for any info on this,,Doug
Old Feb 8, 2011 | 05:54 PM
Mike T's Avatar
Mike T
You're going to have to break the bead on the tire and put something on it. Personally I use dish washing liquid. They make stuff specifically for that, but that is what I use.
Old Feb 9, 2011 | 04:51 AM
grbrown's Avatar
grbrown
Its possible there is corrosion of the rim under the bead that can cause that, or a feather edge of the bead tucked under it. Can't see any solution than remove it to check all is well, then refit with a sealant as Mike suggests. All the tyre fitting shops use it to help fit new tyres.
Old Feb 9, 2011 | 11:05 AM
rh8234's Avatar
rh8234
When I change my tires, I inspect the rims carefully to make sure there is no rubber from the old tire stuck on the rim where the new tire is supposed to seal. I use a scrung to clean the surface up, and like has been said before, I use dish soap to lubricate the bead when installing a new tire. I have been told that this is a "NO - NO" an you should always use a special lubricant. I've been installing tires like this for over 40 years and never had any problems.
Old Feb 9, 2011 | 07:32 PM
shuggy's Avatar
shuggy
Thanks for the responses guys,I will try the dish soap and see how it goes
W.Glide
Wheels/Tires
Sep 30, 2025 04:15 PM
Scrmnvtwins
Wheels/Tires
22
Oct 30, 2017 03:27 PM
Booey424
Apr 8, 2012 09:30 PM
young n bag'n
Jan 23, 2011 10:38 PM
2tonebob
May 19, 2008 09:00 AM
