Tire size increase
Old Apr 10, 2011 | 09:58 AM
scotty-48's Avatar
scotty-48
6th Gear
Question Tire size increase
I've got an "85 fxwg....Thinking of bumping up the rear tire size from a 130 width to a 140 (Dunlop) . Belt drive Evo in a 4 spd. swingarm frame.....anybody done this ? looks like there's about 1/2 " clearance between the belt & widest point of the 130 tire.........Thanks in advance for any info !
Old Apr 10, 2011 | 12:41 PM
Mr. Lucky's Avatar
Mr. Lucky
Assuming your rim is wide enough for the 140 tire, you should be able to do it. A half inch = 12.7mm. Your proposed tire size is 10mm wider (5mm each side of center).
12.7 - 5.0 = 7.7mm clearance (a little over a quarter of an inch)
Old Apr 11, 2011 | 03:11 PM
scotty-48's Avatar
scotty-48
6th Gear
Default Inceased tire width
Thanks a lot Lucky ! Just what I needed !!
Old Apr 12, 2011 | 04:50 AM
grbrown's Avatar
grbrown
Can't speak for a WG, but I had a 140 in my FLHS. I don't recall there being as much spare room as you mention, I had to trim my belt guard to get the wider tyre in. There was 3/16" clearance and I used an allen key as a guage to check clearance, when adjusting the belt!
The widest tyre you can fit on a 3" rim is 150 (at least according to Avon). I have one now, with a narrow belt. Fitted width is 153mm. My Avon Venom 140 was 139mm wide. I never measured a stock tyre!
JoeD-8541
Jun 17, 2020 09:53 PM
kage
Wheels/Tires
Apr 24, 2012 02:00 PM
Plow64
EVO
17
Mar 26, 2012 07:31 PM
79lowrider
Oct 5, 2009 05:12 AM
brwdarr
EVO
May 14, 2009 05:07 AM
