tire
Old Apr 21, 2012 | 10:35 PM
kage's Avatar
kage
Stage II
Default tire
What is the biggest tire I can put on a stock 2001 Electra glide classic?
Old Apr 24, 2012 | 02:00 PM
grbrown's Avatar
grbrown
You should find there is plenty of room for an MU/85, which is one size wider than stock. An MT is 130mm wide, an MU is 140mm.
You may just about get in a 150/80, but not everyone has been successful. That is the widest size it is wise to fit on a stock 3" rim. The limitation is clearance with the belt. You can best measure this by removing the belt guard. You can fit a narrow spacer behind the rear pulley, but there is limited clearance between the pulley and swingarm!
Also be aware that the actual fitted width of tyres is not constant and can be different between brands. For example Avon 150/80 V speed rated tyre is wider than their H rated.
JoeD-8541
Jun 17, 2020 09:53 PM
mac777
Feb 28, 2013 07:08 AM
scotty-48
Wheels/Tires
Apr 12, 2011 04:50 AM
Jakob101st
Wheels/Tires
Mar 24, 2010 01:05 AM
79lowrider
Oct 5, 2009 05:12 AM
