ABS question
Old Mar 15, 2012 | 11:51 AM
CaptainB's Avatar
CaptainB
1st Gear
Default ABS question
I am not a fan of ABS being a long time road racer it takes away my control. It has also gotten me into trouble on a couple of occasions. Riding down a steep winding pass in VT. last year I hit a bump in a turn and the ABS released my front brake sending me into the oncoming traffic lane! I can see the advantages in wet or sandy conditions but as an agressive rider it scares me more than helps me.
My question is, if I pull the fuse for the abs will it disable it? And if so, is there any reason that I can't put a switch in line to disable it on command?
Hope someone can help! Thanks, Scott
Old Mar 15, 2012 | 01:22 PM
qtrracer's Avatar
qtrracer
I was told by another member on here, (kingkingking) to follow the abs wire that runs up the left fork leg from the sensor and when you find that plug behind the fairing to unplug that plug. I have not verified that yet but he says it does disable the system. If that is the case then getting 2 more plugs and wiring in switch that can be removed upon resale would be fairly easy. I feel the same way you do towards this system in the way it works presently.
Old Mar 15, 2012 | 05:40 PM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. I suggest you take a look in the Touring forum, where you may find the answer to your question, and there will be many more readers of your question. Not many members call in here, as you can see from the post counts.
It is also worth checking with your local dealer, as I understand the ABS software has upgrades that are said to improve the way it works.
Old Mar 16, 2012 | 07:01 AM
CaptainB's Avatar
CaptainB
1st Gear
Thanks GTRRACER I may try the front wire trick (and nice tuna, my son has a 25' Blackfin). GRBROWN you are probably right about the other threads, I'll try that.
Old Mar 16, 2012 | 03:48 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You can unplug the abs sensor to disable but the abs light on the dash will come on.
CaptainB
Jul 19, 2024 03:14 PM
Joe from So Cal
Nov 15, 2020 10:39 AM
Jerry1834
Apr 6, 2011 07:15 AM
harley0711
Oct 6, 2010 08:02 PM
SUPRPIG
Jun 24, 2010 07:43 AM
