Allen head stripped
Old May 4, 2012 | 05:01 PM
CD3's Avatar
CD3
Stage I
Default Allen head stripped
First time here and first post.
I have a 04 Sportster and I'm trying to remove move the rear break pad pin. Bought breaks and pin, grabed my 3/16in allen tool and presto smasho I stripped the head out........How do I remove the pin with out jacking up the caliper??? any helpful hints to remove this?? I was told an easy-out and I'm sure that will work but the pin seems to be really torqued down.
Dom
Old May 23, 2012 | 06:05 PM
hotrodd50's Avatar
hotrodd50
Use allen head that is attached tto a socket. Hammer it in tight and use hi-torque impact gun. You will probably need new bolt.
Old Jul 9, 2012 | 08:22 PM
brainnectar's Avatar
brainnectar
Another option you could try is to take a Hex socket and a ball peen hammer. Pound it in their and then tap on the socket a little more to "loosen" the stuck bolt, then wala....it should come out.
Old Jul 9, 2012 | 08:42 PM
davidwruth's Avatar
davidwruth
They make allen wrenches that are taperred for that reason you have to tap them in but they make a snug fit.
Old Jul 19, 2012 | 12:40 AM
Potato_Potato's Avatar
Potato_Potato
I did the same — the problem is the Allan is metric, 5mm and I used a SAE Allen wrench that seemed to fit.
It was over 2 years ago and I can’t remember how I got it out. Can you get a small vice grip on it?
brad75raiders
EVO
28
Mar 1, 2022 10:01 PM
Rickr01
Dec 2, 2013 04:09 PM
user 46092
Exhaust System Topics
Aug 22, 2013 06:28 AM
Aaronbagby
May 9, 2013 09:24 PM
04fxdwgi
General Topics/Tech Tips
Apr 5, 2008 11:01 AM
