Stripped/Mangled Allen Key Head
Old May 8, 2013 | 12:19 AM
Aaronbagby's Avatar
Aaronbagby
Default Stripped/Mangled Allen Key Head
I am trying to remove a Kuryakin Hypercharger that was installed by the previous owner of my Sportster so that I can get to my carburetor. One of the mounts that holds it to the engine is being held on by a ridiculously tight allen key. I stripped the head out badly trying to take it off (using the correct size allen wrench). I then tried the hacksaw/flathead screwdriver trick, and accomplished nothing except breaking a few small chunks out of the surface of the bolt head and further mangling it. My only idea at this point is to try an easy-out, but the hypercharger itself is blocking my work angle. I'm running out of ideas, and getting nervous about this bolt. I don't want to mess it up so bad that I can't retrieve it. Help me please!
Old May 8, 2013 | 04:54 AM
fourhour's Avatar
fourhour
Carefully apply some heat to the bolt to burn the Loc-tite off of it then use the screw driver or channel locks if possible.
Old May 8, 2013 | 04:58 AM
katobird's Avatar
katobird
If you can get a drill on the allen head drill it off, remove the hyperjunk, then vicegrips to remove stud?
Old May 8, 2013 | 05:42 AM
joe.1955's Avatar
joe.1955
Dremel tool with a cut off wheel will remove the head of the bolt, remove the Hypercharger and vice grips to remove the bolt.
It it still won't come out, double nut the bolt or weld one on the bolt.
Old May 8, 2013 | 06:00 AM
Harleycruiser's Avatar
Harleycruiser
Heat.
Old May 8, 2013 | 06:52 AM
cdestuck's Avatar
cdestuck
How about that FREEZE stuff that is sold in spray cams. I think by locktite
Old May 8, 2013 | 07:03 AM
1flhtk4me's Avatar
1flhtk4me
Can you get a small chisel and hammer in there?
Place the chisel on the side of the head,hit it with the hammer to try to unscrew it.
Old May 8, 2013 | 07:47 AM
wraplock's Avatar
wraplock
Sears sells a set of stripped bolt head extractor sockets. They look like regular sockets until you look inside the business end. There are a set of hardened reverse flutes. You select the appropriate size for the bolt, tap the socket on the bolt head, set your ratchet wrench to remove and have at it. The reverse flutes bite into the head as you work the ratchet to remove the bolt. I have used these a few times and they work great!
your PO may have used locktite on the bolt. A little heat will soften it and then you can use the above sockets.
Old May 8, 2013 | 07:59 AM
DM1975's Avatar
DM1975
You can use an EZ out or take the bolt head off with a side cut chisel if heating it up and using vise grips doesn't work, or you don't want to heat it up.
Old May 8, 2013 | 08:07 AM
firefighter616's Avatar
firefighter616
Calm down and go at it slowly with a few of the advices given here......Go slow.
