Do you seriously think that you only need to check tire pressures once a year?
You should check it every ride, which I don't do. But I always check it at least once a week, more if I am on a trip. The tire is the only thing between you and hitting the road.
I am not one of those guys who thinks you have to do your own wrenching to ride. But you got to have a little common sense, and check your tires, lights and controls every once in a while.
Obviously if you take a look at some of my other threads, maybe you'd realize I'm not an idiot.
I never check my truck tire pressure. Why?
Because in a properly installed tire with no issues, air leaks shouldn't happen.
And if they do, it won't add air, air will be removed, such is physics.
So if I see no physical signs to check it. (remember in my first post when I asked if it was normal wear) yeah, I'm going to ride rather than waste time checking my tire pressure. Been doing it for 3 years and no issue
I'm aware it may not have been cared for correctly. But **** dude, give a guy a break. Are we really in kindergarten? Is name calling nessecary.
[quote=Anixon88;10033631]I'm going to ride rather than waste time checking my tire pressure. Been doing it for 3 years and no issue
quote]
You're a pro I guess. On behalf of the entire forum and the thousands of years of combined riding experience I'd like to apologize for any hard feelings.
It's true, a tire lose's air over time. A known fact, under-inflated tires build heat, which leads to premature failure. Thats why all the road gators on the highway from trucks, under-inflated tires due to driver negligence. I owned 22 tractors and trailers at one time, and the drivers too lazy to check the pressure even once a week, cost me a lot of money for tire repairs. The ones that went thru a shop and had pressure checked very seldom had a problem, unless picking something up off the road.
But I've never put air in it, and like i said, it was at the shop last year, so I'd assume they'd check the sort of thing like tire air pressure.
You have got to be phucking joking!
Never check air pressure and tires dont lose air,WOW.
Anixon, I hope you are pulling our leg. I am pretty paranoid about having a blowout, so I use TPM valve caps. When I installed them on my FLHTCUI, they were ripped off by the rotors. The front leaked until I was down to 5PSI. I stopped because it was impossible to steer. BUT JUST LOOKING AT IT, IT LOOKED FULLY INFLATED BECAUSE MOTORCYCLE TIRES HAVE STIFF SIDEWALLS. So basically a visual inspection tells you nothing.
