Bad Front Bearing, Replace as a Pair?
Old Aug 4, 2012 | 08:21 PM
Ridewva's Avatar
Ridewva
The problem is on ABS bikes the left bearing is a different number, incorporating the sensor, so I may be dependent on OEM.
Old Aug 5, 2012 | 07:53 PM
arkeglide's Avatar
arkeglide
I had a bearing failure this morning, I had to run an errand for my wife in the next county so I thought I would take a ride before it got to 100 degrees. I heard a popping noise in the front while I was chasing down a BMW and slowed down to listen closer. When I started to speed back up, it started popping and squeaking so I slowed and hit the front brakes, thats when I felt the vibration and the fork started to wobble. One hour later it was loaded on an roll back headed to my dealer. They are closed on Sundays, so I will get with them in the morning. I had no idea that this is a common failure. My HOG membership paid the first $100.00 on the tow bill. Will the extened warranty pay the difference? The tow company hit me for anohter $130.00 for a 50 mile run.
Old Aug 6, 2012 | 06:26 AM
REDHEAD's Avatar
REDHEAD
Angry Check the number on the NEW bearing from HD
Don't know about the towing.
Make SURE that your HD shop uses the New bearing 9276A out in 2012 models
the "A" after the 9276 HD part tells you that "change" has been made.
The bearing number with the 9276 "A" is supposed to be IMPROVED.
Maybe they put Grease into it this time..
There have been a lot of failures on the bearings...
Not sure of What was done to improve the 9276 bearing ? vendor? but I'm putting in "A's" when my front tire is replaced next week or so...
Probably will do the rear myself as the tire is 60% yet.
45,000 on my 09 King and getting a little worried about Mine.
For those who Want Change,,,,,
the SKF are a fine replacement #6205 2RSJEM
signed....REDHEAD
Old Aug 6, 2012 | 07:31 AM
Ridewva's Avatar
Ridewva
Originally Posted by arkeglide
I heard a popping noise in the front while I was chasing down a BMW and slowed down to listen closer....
That sucks having a failure on the road but I guess it could have been worse. And think how good you made the BMW rider feel, having “pulled away from the Harley that was trying keep up”!
Originally Posted by REDHEAD
Make SURE that your HD shop uses the New bearing 9276A out in 2012 models the "A" after the 9276 HD part tells you that "change" has been made.
The bearing number with the 9276 "A" is supposed to be IMPROVED....
REDHEAD
Good info Red. Checking my work order thankfully they did use a 9276A on the right side, which was the one that failed. If the bike has ABS the left side uses a different bearing. In my case they used a 9252, no "A".
Old Jun 19, 2013 | 08:39 PM
Dew Me's Avatar
Dew Me
Reviving an old thread instead of lazily starting a new one. So with ABS we are stuck with the Harley factory bearing on the left? I'd like to use SKF, Timkin, or some other reputable bearing.
IBHarley
Oct 5, 2016 09:59 AM
FATKEVIN
Aug 20, 2015 05:48 AM
archergodwin
Wheels/Tires
Jul 21, 2014 10:28 PM
leafman60
Sep 24, 2011 06:08 AM
jjjlsj
Oct 8, 2010 07:34 PM
