Burly Cable Kit Question
Old Dec 8, 2012 | 03:24 PM
Contrails's Avatar
Contrails
Default Burly Cable Kit Question
So I'm getting ready to order cable for the bike and have a question. I have a '98 FLHR that I'm converting to a single disc up front using a Jaybrake six piston caliper. I already picked up a 9/16 master cylinder off ebay so now all i need is cables.....
Trying to find a cable extension set for less than an arm and a leg, and ran across burly cable kits. They dont make a kit for exactly my scenario, but here's the question.
If I order a kit for an '00 sportster, will this work on the bike? It should come with the correct length of brake line, the only questions are will the clutch/cable extensions be the correct length for it, and will the fittings fit (ie the connections between the cable and the clutch)? The wiring harness i'm not too worried about, worst case I can always modify it myself for the correct amount/length I need.
scoriden
Apr 19, 2013 02:17 PM
perryross
Jul 6, 2012 06:58 AM
perryross
Mar 17, 2012 08:53 AM
johnwyz
Oct 26, 2010 03:34 PM
jaymacs2
Feb 15, 2009 12:55 PM
