wheel question
Old Jan 10, 2013 | 06:00 PM
philc814's Avatar
philc814
Default wheel question
I have an 03 springer soft tail with a 16" rear wheel, will the 17" solid rear wheel from an 03 duce fit? and will there have to be any any mods?
any help would be appreciated.
Old Jan 12, 2013 | 11:03 AM
grbrown's Avatar
grbrown
I have just squeezed one into my old Glide, although it was not an easy bolt-in. I think the answer is yes, although it would be worth calling into the Softail section and asking in there. Not many members call in here.
You can do some research by going to Ronnies HD website to look at the microfiches in there and comparing part numbers between your bike and a Deuce. I think you will find they use a different rear pulley, although you can get round that by using an accessory shim. The reason for that is the wheel is actually hollow and any other pulley will leave holes in the hub open, which rain water can get in.
cowboy 51
EVO
15
Feb 18, 2013 11:19 PM
psycho-relic
Feb 7, 2010 03:42 PM
1Harleyrdr
Mar 20, 2008 08:15 PM
ST Deuce
Mar 30, 2007 06:14 PM
flexx220022
Oct 23, 2006 11:31 PM
