How often do axles require grease?
Old Apr 13, 2013 | 04:57 PM
see22ds's Avatar
see22ds
Default How often do axles require grease?
Hey all I have an 01 wide glide i picked up a few months back, it has just shy of 5,000 miles. I have already changed all 3 holes and the fluids looked good. My question is how often should the axles be lubed? I do not have an owners manual but am planing on picking one up. I have already logged a few hundred miles, but do not want to keep riding if axles need maintenence. Took me 42 years to get a Harley and want to do all I can to have it last a few years. Can someone advise me?
Thanks.
Old Apr 13, 2013 | 05:15 PM
Jesla's Avatar
Jesla
uh....never.
The bearings are sealed also.
Old Apr 13, 2013 | 05:21 PM
Stiggy's Avatar
Stiggy
Originally Posted by Jesla
uh....never.
Uh WRONG.
I can't tell you how many times we beat axles out of their bearings just to do a simple tire change for a customer.
You don't have to do anything now, but when you do pull the axle for a tire change or whatever, give it a little anti seize so that the next time it'll slide right out for you.
And yes the bearings are sealed and require no maintenance.
Old Apr 14, 2013 | 09:36 AM
tripn88's Avatar
tripn88
I put grease every time I pull the axle or every tire change.
Old Apr 14, 2013 | 09:46 AM
luc.who's Avatar
luc.who
+ 1 The last time I changed my front tire, I had a terrible time getting the axle out. When I put it in with the new tire and wheel, I made sure I had anti seize on the axle. I only do this with tire change or pulling the wheel.
Old Apr 16, 2013 | 10:29 PM
doc ock's Avatar
doc ock
uh....never.
Technically correct just a little anti seize at each tire change goes a long ways.
slammed05fatty
Aug 7, 2013 08:35 PM
Lawdawg
Nov 5, 2011 04:33 PM
Reaper22
Aug 11, 2011 07:59 PM
tennmoto
Apr 28, 2009 11:51 AM
charger
Jul 31, 2007 02:22 AM
