New Tires - Braked Hard during first ride - Advice?
Old Apr 19, 2013 | 10:05 PM
ArmyDoc1993's Avatar
ArmyDoc1993
Stage II
Exclamation New Tires - Braked Hard during first ride - Advice?
Hey -
New to Forum; but I have repeatedly heard a variety of break-in techniques for new tires. Usually around doing a lot of figure-8s, turns and to avoid fast acceleration or braking during the 1st 100 miles. I also see mixed advice as to whether to scrub the tires with a variety of solutions or abrasives, and others that say absolutely not to do this.
Two things:
1. On my first bloody ride home from the H-D dealership after getting new tires, I was put in a situation where I had to brake hard enough to skid several feet. No problems noted during the rest of the ride -- but I hear a ton of concern regarding the need to avoid just that during the tire break-in period.
2. This is my first set of new tires and the bike feels kind of squirrely under me during the ride home. Almost as if it was overly-sensitive. The least amount of lean or front tire movement would alter the bike direction. Some might say that it was "more responsive" than with my old tires. I even wondered if the PSI pressure was too high in the front tire resulting in a smaller surface area with good road contact.
Any comments/advice welcome.
Doc
Old Apr 25, 2013 | 02:53 PM
grbrown's Avatar
grbrown
When buying tyres here in the UK most dealers will recommend taking things easy for around 100 miles. The reason is to scrub off the shiney moulded surface of the tread. There are better things to do with one's life than to mess around trying any other way! Just go out for a couple of hours, preferably down windy back roads, job done.
Grip will improve once you have that under your tyres, however check tyre pressures! I always do that after fitting new tyres, before I take that two hour ride. If you are using a non-stock brand of tyre, check their website for correct pressures - they may be different to stock pressures. New tyres always feel different to the ones that were replaced, even if they are identical.
Old Apr 28, 2013 | 05:24 PM
ArmyDoc1993
Stage II
Thanks Graham -- I did just that; logged about 120 miles and feels pretty much like my old ride. Although that "over responsiveness" up front seems to persist a bit.
Thanks
Doc
Old Apr 28, 2013 | 07:10 PM
Bodean46's Avatar
Bodean46
grbrown, I put a set of Continental Milestones on my 01 Ultra. The tire air pressure is shown in bars on the web so i'm not sure where ideal would be. I'm running 38 psi front and 40 rear and wonder if you can set me straight on proper air pressure. I'm 240 and the wife is 185 and I ride mostly 2 up. have I got the pressure close. Continental's web site just gets me more confused as it's set up more for European riders.
Old Apr 29, 2013 | 05:44 AM
grbrown's Avatar
grbrown
Ah, Continental! They do have a strange website, which is really European and takes us to their German website. The fitment guide won't work at present, so I have used their UK site. That indeed shows front pressure at 2,5 and rear as 2,7 bar. Just multiply by 14.5 to get 36F/39R, although I guess that is solo.
That is pretty well the same as stock, so you could use the data in your owners manual. For 2-up I personally would add several extra psi and would use up to 40F/45R, although I haven't used Continental for many years, so have no experience of their current tyres.
Old Apr 29, 2013 | 05:47 AM
Bodean46's Avatar
Bodean46
Thanks. I couldn't figure it out and no one around here had any idea, so, I just set them according to the owners manual. Feels like front wants to wander a bit more with these than the Dunlops but I think an increase in both might be the ticket.
Old Apr 29, 2013 | 05:58 AM
grbrown's Avatar
grbrown
I look on recommended pressures being a guide, not cast in concrete! With my Avons I used to run them at 44F/50R fully loaded and the bike rode like a champ (I have a custom rear now, so have to settle on suitable pressures for my 160/70).
Having owned Harleys since the 70s they have always seemed to me to be light on psi, especially when riding 2-up. Mrs B and I and are close to your weights so we are on the gross limit of our old Glide and I have worked steadily up the pressure scale to get the ride I want. A little experimentation will probably work out fine for you two as well!
dhook57
Jun 12, 2013 10:06 PM
Dax4800
Apr 16, 2008 02:06 AM
vicks96
16
Sep 4, 2007 07:20 PM
Nomadic RAM
Nov 30, 2005 10:42 AM
sturgisfatboy
Sep 16, 2005 11:33 PM
