Tire Direction
Old Mar 15, 2014 | 10:40 PM
racehorse's Avatar
racehorse
Default Tire Direction
I have been told that tires should be mounted in the right direction. Also, that the tire has a mark that should line up with the tire valve. Is this true? If so, how do you tell if it is mounted in the right direction and what tire mark is suppose to line up with the valve?
Old Mar 15, 2014 | 10:46 PM
deano360's Avatar
deano360
the tire does have a direction arrow on it but im not sure about the mark for the valve stem, that doesnt sound reasonable to me... its not like every rim has a certain way that it has to be made or mounted to the hub
Old Mar 15, 2014 | 10:54 PM
Deucedog's Avatar
Deucedog
Most tires that are uni directional will have an arrow on the sidewall indicating the direction of rotation. Also, the tread pattern will often indicate the direction of rotation. Many tires will have a 'dot' on the sidewall that is supposed to line up with the valve stem hole in the rim.
These site will help ya figure it out.
http://www.ehow.com/how_5028593_unid...nal-tires.html
http://www.americanmotorcyclist.com/...ignations.aspx
Old Mar 15, 2014 | 11:01 PM
racehorse's Avatar
racehorse
Default Tire direction
Thanks for the help!!
Old Mar 15, 2014 | 11:08 PM
Deucedog's Avatar
Deucedog
Glad I could help
Deano: It's not about the rim, it's about the tire.
Old Mar 15, 2014 | 11:13 PM
deano360's Avatar
deano360
Deuce: thanks for the input, i knew about the direction but was unsure with the valve alignment... thanks for the correction
Old Mar 15, 2014 | 11:19 PM
Deucedog's Avatar
Deucedog
No problem guys. I always check the date of manufacture on tires when I put them. There have been problems in the last few years with people ending up with old new tires.
Old Mar 16, 2014 | 10:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Motorcycle tires are marked with a dot that is lined up with the valve stem hole on the wheel. This marking has been a common practice since the 60`s, or maybe even earlier.
Old Mar 16, 2014 | 10:18 AM
ynots's Avatar
ynots
I was told the dot (mark) on the tire has to do with balancing so the heaviest part of the tire goes opposite of the valve stem
Old Mar 16, 2014 | 10:54 AM
Uncle Larry's Avatar
Uncle Larry
All tires have a spot ( designated mark ) that should be aligned with the valve stem. This makes it a bit easier to balance and generally will require less in the way of additional weight when balancing.
