89 Brake upgrade
Old Mar 30, 2014 | 09:53 PM
argo921's Avatar
argo921
Stage IV
Exclamation 89 Brake upgrade
I have a 1989 Ultra Classic Tour Glide. I want to put on 2008 Harley tour wheels, but I want to use the 2008 rotors. I was wondering if there are any calipers that will bolt to the 89 forks but use the 2008 rotors.
Old Apr 1, 2014 | 01:22 PM
grbrown's Avatar
grbrown
Red face
Hi from the UK and welcome to HDF. 1990 Glide here, owned from new, but far from stock. You are covering several things with your query!
Your bike has 3/4" wheel bearings, but the '08 wheels have 25mm bearings, so your new wheels are not going to be simple to fit. The rear pulley will not swap over, from old to new, as it has a smaller central mounting hole than the '08 wheel. In addition your current rear brake rotor is larger in diameter, also thicker than an '08, so will not work with your current rear brake caliper.
Moving to the front, your new wheel will not work with your current axle and to fit later calipers will require adapters, to mount them on your sliders. In other words IMHO there is nothing about your plan that is straight-forward! It can be done, but the list is long and many more parts will be required.
Old Apr 5, 2014 | 06:24 PM
argo921's Avatar
argo921
Stage IV
Thank you for the reply. I think I will be able to make the front wheel work. I haven't started working on the rear wheel yet.
Old Apr 6, 2014 | 05:29 AM
grbrown's Avatar
grbrown
I have a later swingarm, wheel and rear brake in my own bike, partly to upgrade braking, but also to get the later beefed up swingarm.
Old Apr 6, 2014 | 08:35 AM
argo921's Avatar
argo921
Stage IV
What year swingarm did you use.
Old Apr 6, 2014 | 09:05 AM
grbrown's Avatar
grbrown
I found an '07, but any year from 02-08 can be used. If you want to know more take a look at my thread here, but get a long drink first!
Old Apr 21, 2014 | 07:40 PM
argo921's Avatar
argo921
Stage IV
I was able to use the 08 rear wheel with a 89 front rotor. I had to modify shims to get the proper alignment but it worked out. Thank you for your replies.
97EGC
Jan 29, 2018 08:29 AM
Mcarso1
Aug 2, 2015 05:51 AM
misfitJason
EVO
20
Dec 19, 2014 12:39 AM
bradleys1320
Apr 19, 2014 10:58 AM
Rabid1
Dec 9, 2013 08:24 AM
