no just saw the nail during a check ,,never lost air ,, just be ready to ride it when you pull the nail and it will seal rtght up ,, I pulled the nail and lost a lot of air put more air in rode around the block and no leak
So probably out in the middle of nowhere, better to leave nail in until you get to air source?
I see you have spokes.
There was a report way back on the forum were someone did a self test before a tire change using such a product.. seemed to help on a tubeless tire.
You are running spokes so you have a tube which would reduce effectiveness.
The area covered is in the exact center 1/3 of the tire..
I did acquire a nail once on a tubed tire... I did not have any product in the tube and tire that was discovered totally flat after finishing my lunch. Flat was from a thick nail..roofing tar paper nail....I did have an electric pump and was able to air-up several times until i reached help...i now carry some slime and similar pump...i have used the pump to help several motorcycles and once even donated pump to a couple in distress..I have only used the slime to help bicycle riders in the middle of no where with success..Again i have not used it on a motorcycle .. Link to the pump idea: http://www.webbikeworld.com/Motorcyc...cles/air-pump/
If you have mags then a pump as linked or similar and a simple thread plug kit should get you going with a simple flat.
If you do not wish to de-construct a pump then you can look at one of the small slime brand pumps.
