99 night train 150 tire
Old May 14, 2014 | 08:48 AM
99NTrain's Avatar
99NTrain
1st Gear
Default 99 night train 150 tire
I have a 99 evo powered night train. It's all stock. I have read that others have put 18x4.25 rims with 150 rubber on their softails. I can't tell if it will fit mine as harley used a few different belt sizes. Will if fit?
Old May 14, 2014 | 10:34 AM
grbrown's Avatar
grbrown
How wide is your drive belt? If you have the early 1 1/2" wide belt there is very little clearance. Tyre widths are often different from brand to brand and not always the exact width they are stated as being. My 150/80 Avon measured 153mm wide on my wheel. If you have a later narrow belt, such as a 1 1/8", you have enough room to get one in.
It isn't necessary to change wheel to install a 150/80 tyre, you can get them in 16", which I have successfully used. Later Harleys used that size, on stock 162 x 3" rims (some Sporties still do).
Old May 14, 2014 | 11:58 AM
99NTrain's Avatar
99NTrain
1st Gear
I want a spoked rear wheel and really dig the lower profile of the 18. If I have to convert to a narrow belt I would. I just always had jap cruisers so making stuff work on a harley is new to me.
Old May 14, 2014 | 12:00 PM
99NTrain's Avatar
99NTrain
1st Gear
This is the rear wheel size and tire I want to run.
Jsdrillin
Feb 19, 2018 09:27 PM
Droopy2012
Jan 30, 2015 07:26 AM
98Chop
EVO
Mar 12, 2012 01:54 PM
JIMSFBL
Sep 9, 2011 11:22 AM
FCM
Mar 23, 2010 07:12 PM
