Grab rail for Heritage Softail
And It Does Fit The 2000 To 2006 Heritage Classic, But With This V-rail You Can't
Put On A Back Rest Pad, If You Want The Pad Then Your Going To Have To Put On A Springer Seat And Drill 2 Holes On Your Fender, It's A Hard Mix But It Does Work, I Ride SOLO So I don't Need The Two Up Buddy Seat, The BottemTwo Picture Is My Bike With The Springer Set Up On It
Good Luck
Harley03joe
The One From V-TWIN Bolts To Your Upper Rear Fender Struts
If you're planning on this change, do it soon as the rail and rider's backrest pads are obolete and most dealers won't have them in stock.
Your Very Welcome Kizthewize,, What Are You Going To Get ?The V-Rail From V-Twin
Or The Springer Seat ?? Let Me Know Ok
My E-mail is >>>Jjvjjv@aol.com
So It All Worked Out A-OK. Just Had To Drill Two Holes In My Fender , I Used A UNI BIT And A Dremel with a Diamond bit To Make The Right Side Hole Ovel , And Was Careful Not To Drill Tru The Wires That Run Down The Right Side Of The Rear Fender, The Painted The Holes Silver, Its Just Like Factory Now, And The Heritage & The Springer Fenders Are The Same
One Might Say I Made It My Own
You will need to start with a springer or deluxe seat.
