Weird noise when hitting bumps
Old Sep 19, 2014 | 10:17 PM
Bearcat1's Avatar
Bearcat1
Same here. I have no idea what it is. I have checked everything I can think of to no avail.
Old Sep 19, 2014 | 11:08 PM
DannyZ71's Avatar
DannyZ71
Not sure about the Street Glides since they have passenger "pegs", but my passenger footboards make a little racket also when they're folded up and I'm solo. But with the wife on, the noise goes away. And I do think there is some noise from the front forks as well.
Old Sep 19, 2014 | 11:18 PM
Custom96's Avatar
Custom96
It's a mystery!
Old Sep 20, 2014 | 12:41 AM
YPD485's Avatar
YPD485
Rear brake pads have a tendency to rattle on bumps when the rear brake isn't applied. Found it on mine by tapping the rear tire with a rubber mallet. Brake applied, doesn't make a peep. Fixed mine with some disc brake quiet.
Old Sep 20, 2014 | 11:38 AM
rollin_fatboy's Avatar
rollin_fatboy
I've had the same noise since day 1. I thought they forgot to tighten something in the front end. My brother rode it for 3 miles on the first day, turned around and said something is making a noise in the front end. I wouldn't say I feel anything in the floorboard though. Just an obvious clunk from the front.
Old Sep 20, 2014 | 11:49 AM
Just Me's Avatar
Just Me
I have always blamed it on the kickstand?
Old Sep 21, 2014 | 01:09 AM
FLHXSS's Avatar
FLHXSS
3rd Gear
I have a clunking noise coming from the right rear someplace. I took it to the dealer. They said it was the strut contacting the fender and put some rubber padding between the two and said its fixed. I call bs cause I still hear it and it pisses me off.
Old Sep 21, 2014 | 01:37 AM
Jackie Paper's Avatar
Jackie Paper
If it truly is in the headstock and appears to sound like it is almost on the rebound rather then when you first hit the bump. Then check the fallaway or torque on the head stock bearings called out in the service manual. What is crazy is I have found it to be opposite of what you think you should do. If the fallaway is in the upper range, set it to the minimum. Those tapered roller bearing do not like to be preloaded tight.
Old Sep 25, 2014 | 12:33 AM
Adam Moore's Avatar
Adam Moore
1st Gear
The clunking is the Saddlebag support brackets moving in and out. They rest under the seat and have no screws or bolts to hold them when they flex. Try pressing your hands on the bracket when you hear the noise and it goes away.......
Old Sep 25, 2014 | 09:03 AM
baldguy13's Avatar
baldguy13
It's the HD secret. You hear and feel the clunk and go to the dealer. While they're looking at it, you buy more accessories.
