Custom Dynamics help
Old Nov 3, 2014 | 07:27 PM
maverick2076's Avatar
maverick2076
Default Custom Dynamics help
I need a little help from you Custom Dynamics gurus out there. I'm planning out my redo of my Street Glide's lighting, and I want to make sure I get everything to do all that I want to do.
For the front, I'll be doing the TL7 and the dynamic strips turn signals.
For the rear, I plan on getting rid of the stock SG signals completely. I want to go with the CD LED Tribar as a run/brake light, the plasma rods as run/brake/turn, and the Plugz as brake/turn lights. I would also like to have a flasher that flashes the brake lights and then goes steady when I apply the brakes. Here is my list so far:
http://www.customdynamics.com/dynamic_strips.htm
http://www.customdynamics.com/street...LED_Fender_Tip
http://www.customdynamics.com/plugz.htm
http://www.customdynamics.com/plasma_rod_led_lights.htm (x2)
PDC's x2
My questions are:
Is there anything else I need to make the lights work the way I want?
Does CD make a brake flasher that works for the 2014 SG? If not, does someone else?
Are the 8" the longest plasma rods that will work on the stock SG fender, or can I go longer?
Can someone recommend a good, clean plate mount, preferably with an integrated plate light, that comes in gloss black and will eliminate the turn signal bar?
Thanks for all your help!
Old Nov 3, 2014 | 07:55 PM
Springerfan's Avatar
Springerfan
Default CD help
I put the Dynamic Strips on mine and doing something similar at the rear with Plasma Rods. For the Dynamic Strips I didn't have to do anything but plug them in, no equalizer needed on the new models. The instructions include a procedure if you get a fast flash and how to clear it but I didn't need it. For the rear you need a breakout module from CD plugs in between the taillight plugs under the seat and splits out the brake turn wires but a bonus is that you can wire everything up to the module without splicing into the factory harness. I can't remember the part # but if you call CD tech support they will tell you exactly what you need. CD does not have a brake strobe for Rushmore models yet but should be out soon. Hope this helps, it's a simple job.
fhartell14
Jul 8, 2017 11:48 AM
14StreetG_cruiser
Electrical/Lighting/Alarm
Mar 27, 2017 11:06 AM
NPV288
Feb 2, 2017 03:52 PM
Cozz
May 18, 2016 07:56 AM
cathead
Jun 7, 2015 10:20 AM
