backrest bracket tips?
Old Nov 29, 2014 | 06:10 PM
scottt's Avatar
scottt
Originally Posted by Bill10256
My backrest has a screw for fine adjustments. Just mentioning it in case you didn't notice one on yours. It's usually covered by the sleeve that covers the bracket.
Are you talking about the frame bracket? Or the backrest?
Old Nov 29, 2014 | 06:19 PM
RG Pilot's Avatar
RG Pilot
He's talking about the backrest itself. You'll notice a grommeted hole in the leather / vinyl sleeve that covers the backrest hardware. You can fit an allen wrench through it to access the adjustment screw. It gives you fine adjustments forward and aft. I used Locktite on mine as I was afraid it would vibrate out.
Old Nov 29, 2014 | 06:20 PM
Bigboyride's Avatar
Bigboyride
Scottt, here is a picture that a member sent me of his CVO and which holes the bracket was mounted from the Factory. These are the holes I used and they worked great for me.
Old Nov 29, 2014 | 06:21 PM
Bill10256's Avatar
Bill10256
It's on the backrest just below the hinge that connects the backrest to the support. The support plugs into the brace. It's covered by a sleeve that covers the support. You have to pull up the sleeve to see it. There's an eyelet on the sleeve to slide a torx through so you can adjust it.
That's how mine is. It's very possible yours could be different.
Old Nov 29, 2014 | 06:34 PM
scottt's Avatar
scottt
Thanks again, I have the bracket all installed. Appreciate the help from everyone. My backrest was scheduled to arrive Friday...the post office messed up, will receive Monday.
adkg12
May 31, 2016 01:02 PM
steelerdude1
Aug 11, 2014 06:43 AM
chief1600
Apr 10, 2013 09:33 AM
Rickr01
Jul 17, 2012 06:15 AM
