Apes and riser bushings
Old Jan 18, 2015 | 09:27 AM
grapeapes's Avatar
grapeapes
Here's where I'm at and my take.
I have a 07 Road king (16,000mi) that the previous owner put 12" apes on. The bars rocked a little & vibrates more than I thought they should so I looked to see what bushings it had. PO had put an extra giant washer under the stock bushing such that the washer contacts the bottom of the tree and squishes the bushings even more.
I took the washer off to see how well the stock bushings would work with just the oem washer cups and the bushings are basically destroyed. tons of play and pretty much fully flattened out, which is why I'm searching for new poly ones.
From what I've read, many have used the stock bushings and were fine at first, but then they deteriate faster than they should and you are no longer able to keep tightening them after a while.
Old Jan 18, 2015 | 09:48 AM
sixshooter's Avatar
sixshooter
I was thinking the same thing about durability. The polys would obviously last longer, but I may wait until they wear out to replace them. The bike will be back apart in a year or two to do trees and a front wheel anyway.
Old Jan 18, 2015 | 12:55 PM
Springerfan's Avatar
Springerfan
Default bushings
I ended up using solid aluminum bushings that the dealer recommended. I wanted to avoid any possibility of play in them.
Turret_plug
May 2, 2017 12:25 PM
TJSX1
2014-2024 Touring Models
Oct 6, 2014 01:45 PM
taygull
Apr 15, 2013 01:19 PM
cf7go
Apr 20, 2012 07:28 AM
Bluegrasser
Sep 24, 2009 08:33 PM
