taillight wiring
Old Dec 11, 2014 | 07:58 PM
golflady158's Avatar
golflady158
2nd Gear
Default taillight wiring
Need some help..... I have a new fender and I custom fit some dual led lights. I have three wires a ground, running and brake. The connector under the seat has six wires on it and looks from the wiring diagram goes thru a converter. My question is can I cut off the wiring harness and wire my wires up to the harness and be able to use my lights as the same without converter, if so how do I wire it?
Old Dec 12, 2014 | 08:55 AM
Springerfan's Avatar
Springerfan
Default rear lights
You need a signal decoder. Custom Dynamics sells one that just plugs in between the stock wiring so you do not need to modify the factory wiring. If you call them they will tell you exactly what you need. I think I paid about $70 but well worth it.
http://www.customdynamics.com/turn_signal_decoder.htm
19mandy.clarkson77@gmail.com
Sep 17, 2016 04:14 PM
Lwood Classic
Jan 7, 2012 07:08 PM
WARG
Oct 18, 2010 09:22 PM
ncbeast
Jun 10, 2009 01:56 PM
rrsjs5
Jan 26, 2009 07:44 PM
