If you improve the flow out the *** end it is best to let it suck easier on the other end, then she wants more fuel. Then you have more noise, (and performance hopefully)
These stock air cleaners flow a little better than the 13-before from stock. So, your question is simple yet perplexing. If you are going to keep stock, then no. If you are going to put on slip fits, then no. If you add a tuner, you don't "have" to. Saying all that. You have to give us a clue to your intentions. If you want more power, then yes. If you change the A/C, then you have to add a tuner. If you have more air going in (AC) and more fuel (tuner), then you want to free up the air going out. How? Simple answer is bust out the cat, add some slip ons. Or you can leave the cat in and add some slip ons. Or you can go true duals or power duals. Sky is the limit. What is your intentions?
Exactly over thinking it. I have everything purchased. But sitting here with arm in sling I have two much time on my hands. We are not building drag machines I know we are giving them a little more fuel with a tuner but how much air flow do they need.
I can't find the thread right now...but essentially that flow test you're referring to determined that the backing plate opening on the new Rushmore models are responsible for the increase in intake flow.
I'll find it later when I have more time, if someone else doesn't get it on here by then.
Incidentally, oiled air filter media flows less air and allows more particulate matter into the intake. Look here.
