Lost oil pump today 19k miles 11mos old
Old Jan 28, 2015 | 08:06 PM
skybox ed's Avatar
skybox ed
Default Lost oil pump today 19k miles 11mos old
thank god for the warranty!!! on my way to dealership today to drop bike off for the 3 time for a cb repair, came to a stoplight half mile away and my bike would not idle. 300- 2500 rpm. I could hold the throttle @ 2k and it would be fine. pulled up to dealership and it died. started it up and pulled in service bay. figured it was a loose battery terminal (had the same symptoms on previous bike). 30mins after I got home I got the call. when they started it, awful noise and only had 4psi oil pressure. when they checked the dipstick, there was none showing. so now I sit and await the verdict.....new or rebuild, and still my cb doesn't work
Old Jan 28, 2015 | 08:26 PM
jockotwin's Avatar
jockotwin
Did they tell you that the engine failure was covered by warranty even though the oil level was not on the dipstick?
Old Jan 28, 2015 | 08:35 PM
skybox ed's Avatar
skybox ed
yes they said the oil was in the crankcase ?? but I specifically asked if it was covered and they said yes. since it is chilly here (28-35F) I always start bike and allow it to warm up before riding (heads warm/hot to touch). no signs of blowing/leaking oil anywhere
Old Jan 28, 2015 | 08:36 PM
Gwaxley's Avatar
Gwaxley
hope this is not another WTF threads and you never learn the truth
Old Jan 28, 2015 | 09:14 PM
GPHDXLC's Avatar
GPHDXLC
Be sure they check the crank run out, that will make the oil pump go bad. Keep us up-dated.
Old Jan 28, 2015 | 09:20 PM
jockotwin's Avatar
jockotwin
I'm new to Harleys. From what I understand, the oil pump consists of 2 pumps. A scavenging pump to remove oil from the crankcase & keep the supply tank full, & a pump to supply pressurized oil from the tank to the engine. If the scavenging pump fails, the supply tank level is low & the engine pump is starved of oil. If that is accurate, I could see how the failure is covered by warranty.
Old Jan 28, 2015 | 09:25 PM
Sea Biscuit's Avatar
Sea Biscuit
Well, if it's under warranty and you are looking at a new engine, maybe time for the new Screaming Eagle 120st...street tuned/legal and full warranty from Harley!
Old Jan 28, 2015 | 10:26 PM
skybox ed's Avatar
skybox ed
thanks a bunch.. that explains why he said the crankcase was full and the no oil on dipstick.
as for the 120st why not the 120r, I personally don't want a hopped up motor. I plan to put travel miles not drag on this one. they have a 120r in a lowglide at the dealership 145hp 135 ft torque. my 03 ultra had the 103 stroker and only lasted 25k. i'll be satisfied with a new 4yr warranted 103 wethead motor, but doubt if that will happen
Old Jan 28, 2015 | 11:47 PM
KMC1's Avatar
KMC1
In this case, wouldn't the engine throw a warning the instant the "pressure pump" sucked air?
Old Jan 29, 2015 | 04:51 AM
cycle7447's Avatar
cycle7447
Community Influencer
If your bike is properly services - and this sort of thing happens, I would always think it is a warranty issue. Even if the oil leaked for some reason, that means something broke, cane loose, etc. This in my opinion would still be a warranty matter.
