6 speed noisy
Old Feb 13, 2015 | 07:34 PM
Bikerscum's Avatar
Bikerscum
Default 6 speed noisy
What is it exactly that makes the 6 speed so noisy? Noisy as in shifting clunk. My new Limited Low sounds like someone's smacking a glass table top with a hammer . Shifting into first from neutral sounds painful. I've ridden along side other similar bikes & mine definitely sounds louder.
Thing is.... not every time. Maybe 1 out of 20 shifts sound like the gears are made of rubber... just that quiet.
This thing makes my '91 Softail sound like an automatic. I'm going to ask the dealer obviously but I'm fully prepared for the standard "they all do that". No, they all don't.
Any advice?
Thanks
Old Feb 13, 2015 | 07:45 PM
Sunnyday91360's Avatar
Sunnyday91360
That's what makes it a Harley, LOL. But I believe you are right. My '10 RK was much louder when shifting then my '14 SGS. It appears to be a hit and miss deal; however, nothing is wrong. I rode my'10 for 33,000 miles and the trans was still solid, noisy but solid. Now you will hear using different oils, weights, brands, etc. will make it all better. I tried gear oil 75-90, 85-140 in several different brands in my '10 RK. Very minor difference, if any. Get ready.
Old Feb 13, 2015 | 07:55 PM
mikeman54's Avatar
mikeman54
Originally Posted by Sunnyday91360
That's what makes it a Harley, LOL. But I believe you are right. My '10 RK was much louder when shifting then my '14 SGS. It appears to be a hit and miss deal; however, nothing is wrong. I rode my'10 for 33,000 miles and the trans was still solid, noisy by solid. Now you will hear using different oils, weights, brands, etc. will make it all better. I tried gear oil 75-90, 85-140 in several different brands in my '10 RK. Very minor difference, if any. Get ready.
Old Feb 13, 2015 | 07:58 PM
HD_Doobie's Avatar
HD_Doobie
Try squeezing the clutch a few times, then hold for approx 10 seconds before shifting into first when the bike is cold. Seems to quiet the clunk, at least for me.
Old Feb 13, 2015 | 08:12 PM
GPHDXLC's Avatar
GPHDXLC
Yes it's normal and has been long before the six speed. My 11 King was very loud and my 14 is a little better. I have a bud with a Polaris Turing bike a 11 or 12 and his makes more noise then my Harley.
Old Feb 14, 2015 | 01:22 AM
YPD485's Avatar
YPD485
If it didn't make the noise, then you have a problem.
Old Feb 14, 2015 | 01:59 AM
Gwaxley's Avatar
Gwaxley
Remove the little hammer and use a quality gear oil should help.
Old Feb 14, 2015 | 06:10 AM
hawg20's Avatar
hawg20
I had the Hyd. clutch line bleed again and it helped mine a lot.
Old Feb 14, 2015 | 06:45 AM
IUOE ROB's Avatar
IUOE ROB
You mentioned your bike is new, don't know if you had the service done yet but mine quieted down some after the initial break-in and the first service, still noisy but quieter. Neutral got easier to find too...
Old Feb 14, 2015 | 07:29 AM
Bikerscum's Avatar
Bikerscum
That's something to think about... mine jumps forward a bit when going into first.
