ride planner help
Old Feb 21, 2015 | 09:22 AM
95ci springer's Avatar
95ci springer
Default ride planner help
I'm trying to create a ride with the HD trip planner and have 5 poi stops. If from my last stop, if I want to get the most direct way back home from my starting point, how do I do this?
Old Feb 21, 2015 | 09:23 AM
95ci springer
Never mind. I just found out by clicking on round trip.
Old Feb 21, 2015 | 09:44 AM
dgreen1069's Avatar
dgreen1069
I haven't played with Ride Planner much, but I believe the bikes navigation will pick it's own route between your POI's. The only way to get the bike to follow a full route is to pick waypoints at every turn you want to take.
Old Feb 21, 2015 | 09:56 AM
95ci springer
This is my first attempt at this. Now I just need some good weather to try it out.
Old Feb 21, 2015 | 10:30 AM
RollaMo's Avatar
RollaMo
Not quite right, but the general idea is correct.
Every GPS devise has its own built in maps and will use their own maps to navigate between waypoints that you import into it.
They also have algorithms that the software will use to calculate that trip, and most give you the option of choosing shortest distance, fastest time, avoid hiways, avoid tolls, etc.
So, depending on your selected GPS settings your unit may or may not follow your "computer" map exactly.
As you mention, adding more waypoints is one way to "force" your GPS built in map to stay on the course that you viewed on your computers mapping software.
Adding waypoints at every turn might be a little over kill in most cases.
It all depends on the route you want to take. In areas where there might be lots of ways to get from point A to point B, you might need more waypoints to follow your course exactly.
In rural areas, in most cases just about any map or GPS will use the same route to get from A to B, then you don't need as many way points.
After you use any mapping software (Ride Planner, or others), you will get a feel for how it converts to your model of GPS built in maps.
Also, keep in mind that your GPS will need map updates from time to time in order to stay current.
You might find a road on your computer mapping software that does not exist in your GPS map.
In that case you will never get your GPS to follow a road it does not know about.
A GPS map update will make these things less of an issue.
Old Feb 21, 2015 | 11:21 AM
95ci springer
How do I get a map update?
Old Feb 25, 2015 | 02:03 PM
Punjabi Rider's Avatar
Punjabi Rider
Any Harley Davidson dealership will love to sell you one but I update every couple years on my cars to add all the new freeways or streets because it's always between $ 100 to $150 . Keep in mind you don't have to update a map to perform you nav better but you can download new software for your radio for free to perform better and it's easy just follow the instructions in your owner manual.
VRSGS16
2014-2024 Touring Models
26
Apr 11, 2018 08:47 AM
SilverEagle50
Road Trips
Apr 24, 2016 08:07 AM
Grousehunter
Road Trips
Aug 12, 2011 05:27 AM
jkeeton81
Jul 16, 2010 10:01 AM
mebetj
Pacific
Apr 2, 2008 09:00 PM
