Head pipe install HELP
Old Mar 10, 2015 | 06:09 PM
timbo141's Avatar
timbo141
Originally Posted by 472viper
I called fuelmoto on this very issue. I was told that when using HD tapered gaskets that there will not be much thread exposed after the nuts are torqued. (99 inch lbs is what fm recommends). Mine did not "click" into position either but they do not leak. My bike had 600 miles on it, I reused the oem gaskets, just left them in the head.
I did the same as 472viper, left the oem ones in. No leaks.
Important part is torque sequence. Follow your manual but only go to 99 inch lbs
Old Mar 13, 2015 | 12:31 PM
472viper's Avatar
472viper
Yes I believe the torque sequence is critical to getting the proper seal and not deforming the gasket which would create a leak.
I'd post the sequence but am 1500 miles from my service manual.
Old Mar 14, 2015 | 04:23 PM
stubby001's Avatar
stubby001
Fuel Moto supplies flat gaskets to match their flat flange, that's what I'm using. The problem I'm having is the front pipe is touching the cam cover and I see no way to correct this.
Old Mar 14, 2015 | 05:42 PM
Howler_LI's Avatar
Howler_LI
If I remember right, I used a large socket & small hammer to gently tap the square-shouldered FM gasket in place. I had to wiggle the back end of the pipe around some & pull a little on the front pipe forward & sideways. Mine is VERY close.
Old Mar 14, 2015 | 09:20 PM
roadglider1's Avatar
roadglider1
Went through this on my 13 limited, I recall FM said to use the flat gaskets and as others have stated get another set of hands to help align the pipes. Again, If I recall
correctly FM stated that their header does not seat into the ports as deep as the stock
header. Worth a call to FM.
sh4325
2014-2024 Touring Models
17
Sep 4, 2018 08:29 PM
JonnyVegas
Sep 12, 2015 08:56 AM
TxFF636
Apr 4, 2013 01:42 PM
HD101st
Jul 6, 2010 05:55 PM
Speedkingnick
Feb 16, 2007 11:18 PM
