Using the kill switch - mandatory?
Old Apr 15, 2015 | 01:49 PM
  #61
MilesOfTexas's Avatar
MilesOfTexas
I'll give the kill switch a try then.
Old Apr 15, 2015 | 01:52 PM
  #62
fatboy slim's Avatar
fatboy slim
Kill Switch.
Salesman was very insistent on the start and stop procedure. Twice I've forgotten and gone straight for the ignition switch like I do on the Kawa and got a TPS error code next time I've started up.
Old Apr 15, 2015 | 01:58 PM
  #63
Gwaxley's Avatar
Gwaxley
Originally Posted by Cool Inferno
Your post in essence kinda confirms JohnnyC earlier post on the shut down procedure. I agree with JohnnyC in that you just don't unplug the power on a computer. You use the shut down procedure. Now I'm more inclined to believe that its always better to use the kill button first.
I agree with also, my LT will try to go through its safe mode after a hard shutdown. It system may have to do something similar.
Old Apr 15, 2015 | 03:10 PM
  #64
MilesOfTexas
I am wondering how the kill switch relates to the infotainment system seeing the infotainment system stays running even after the engine is turned off with the kill switch and doesn't turn off until the ignition is turned off.
I am not saying it doesn't make a difference, but ...
Old Apr 15, 2015 | 03:23 PM
  #65
qtrracer's Avatar
qtrracer
You'd think if the using the ign switch to kill the motor would hurt the infotainment, HD would put a timed relay on the system so it doesn't lose power till they want it to. Autos have more sophisticated electronics with wifi and 4g etc and they don't require you to kill the motor only first before you turn off the key switch, so I'm sure if that was for sure is the answer it'd be easier for HD to do that than do all that warranty work. Maybe its in the pipeline or maybe it isn't the problem, LOL
Old Apr 15, 2015 | 03:33 PM
  #66
Gwaxley's Avatar
Gwaxley
Not sure ether but a computer will want a programs closed before shutting down. The system is reading all engine functions as its running, that maybe considered a running program.
Old Apr 15, 2015 | 03:49 PM
  #67
R-Jay's Avatar
R-Jay
Have never used the kill switch on my '14 Ultra. No problems. BUT... I am very old school and always put the bike in neutral before I shut it off too.
Old Apr 15, 2015 | 03:52 PM
  #68
Cool Inferno's Avatar
Cool Inferno
The kill switch feeds into the BCM I believe if I read the diagram correctly. Now as for the function within the BCM in regards to the kill switch I'm lost. But I'm sure its all part of the programming and design within the BCM. The only way to know the exact function, we will need someone that has access to that data to chime in. The way I see it since it is connected to the BCM, its just not a simple function of just grounding the ignition in order to shut down the motor.
Old Apr 15, 2015 | 07:58 PM
  #69
jpooch00's Avatar
jpooch00
Thumbs up Thanks everybody!
Well, when I originally posted this question, I never expected so many widely varied answers and opinions.
The one thing I've found, though, is that if the manufacturer recommends something in the owner's manual, then there must be SOME reason for it (and if anybody knows the absolutely definitive answer as to why they stress the use of the kill switch, please speak up!).
I'm wondering if it's all nothing more than just going along with MSF guidelines and doesn't really matter, otherwise.
Thanks to all for your responses and opinions.
Ride safe, y'all,
JP
Old Apr 15, 2015 | 11:00 PM
  #70
Shanebo's Avatar
Shanebo
Ride safe, y'all,
JP
I bet this thread goes on for another 5 pages...
On another forum I frequent, they have a section called NEPRT--Never Ending Pointless Recurring Threads. It's where every thread that starts like "What's the best__________?"
Could be oil, tires, Seafoam, or starting/shutdown procedure debate. Many things make it into the NEPRT section, because many things come up for debate with no clear winning argument--ever.
Kind of like this one...
Shane
