Stage 4 Problems!
Old Apr 14, 2015 | 10:12 PM
2008GLIDE's Avatar
2008GLIDE
Default Stage 4 Problems!
I have a 2015 Street Glide Special. It currently has 7200 miles on it. I have the Screaming Eagle stage 4 with a screaming eagle breather and Vance and Hines 2-1-2 head pipe with RC 4" cans. I am having two problems. First from 1000ish rpms to 1900ish rpms it misses and cuts up bad. To the extent I almost dropped it turning left because it died in the turn... The second is my buddy with a 2012 with only cams and some plug in play Tuner is out running me bad!!
Has anyone else had a problem with the stage 4?
Old Apr 14, 2015 | 10:17 PM
2008GLIDE's Avatar
2008GLIDE
The kit:
http://www.harley-davidson.com/store/se-103-ci-performance-stage-4-kit
Old Apr 14, 2015 | 10:50 PM
djl's Avatar
djl
Your link doesn't work. Which kit, street or race? Really doesn't matter but I know several in my neck of the woods that have installed both and they have had similar problems to yours. rideability issues. Dealers typically don't know how to tune and usually download a map, tweak the map and call it good. Find the best tuner in your area and get a proper tune. A proper tune will take 3-4 hours and, in my neck of the woods, will run about $300.
The best tuner in my area tunes for four area dealers. I have seen several Stage IV kit dealer builds come through his shop with rideability issues like you describe but the peak numbers hit the numbers advertised by the MoCo; that is the goal of the dealer tunes. Peak numbers are about the same after a 3-4 hour dyno session but the chart looks much better, the bike is actually fun to ride and the owners leave the shop grinning from ear to ear.
Old Apr 14, 2015 | 11:21 PM
Reno48's Avatar
Reno48
I agree with DJL. I've done a street stage 4 on my 2012 sporty 48. It is producing nearly 100hp and 100ftlbs without changing the displacement. The tuner took nearly 4 hours and a lot of rubber off my rear tire. This guy tuned it at every RPM level to meet optimum performance. During this tune, we also replaced the TTS tuner with a FuelPak tuner because the it allowed for more changes. Be open to changing your tuner and parting with $300 for the dyno. And, yes it is fun beating up on guys with 103's-sorry
Old Apr 14, 2015 | 11:57 PM
cpbedor's Avatar
cpbedor
yup, you need to find a guy that knows how to tune this setup on a dyno and you'll be a happy camper
Old Apr 15, 2015 | 06:19 AM
2008GLIDE's Avatar
2008GLIDE
Sorry didn't realize the link didn't work. It is a Harley Davidson stage 4 street kit. I didn't get the race version because everything is the same except it adds a race tuner and the race tuner will void my warranty. I'm not opposed to spending $300, $400, $500 for Dyno time as long as it fixes my issue. I am NOT confident with my local harley-davidson dealership that they can fix this issue.
Old Apr 15, 2015 | 06:21 AM
2008GLIDE's Avatar
2008GLIDE
Also at this time I do not have a tuner at all. They put a download in it and called it good.
Old Apr 15, 2015 | 07:47 AM
SGNEWB's Avatar
SGNEWB
BINGO there is your problem! I agree with all who have responded above, get a GOOD dyno tune and you will be all smiles.
Old Apr 15, 2015 | 07:53 AM
2008GLIDE's Avatar
2008GLIDE
The problem with that is if I do a tuner it will void my factory warranty. That is the reason I did the download because it doesn't void the warranty.
Old Apr 15, 2015 | 08:08 AM
qtrracer's Avatar
qtrracer
Well you have a choice ,you can live with a bike you hate how it runs for 2 years or buy a TTS(sorry the fuel pak aint gonna cut it, LOL)PV or SEPST and get that sucker tuned by a pro and enjoy the bike. You are correct to stay away from the dealer.
