Too stiff!
Old May 2, 2015 | 07:16 PM
mskirwin's Avatar
mskirwin
I have a '15 ultra limited and no problem with my clutch. It's easier than my '01 softail was.
Old May 2, 2015 | 07:29 PM
heritageblue2013's Avatar
heritageblue2013
Less Viagra per fill up?
Old May 2, 2015 | 08:13 PM
MikeZ's Avatar
MikeZ
Originally Posted by Gwaxley
After the latest recall my clutch is a little easer or easer to brake over and feels smother the full travel. It seems easer to feather and I actually have been able to hit neutral more times than not.
After the recall before this one or the second one it did not feel any different and seemed to have a little tricky spot before full in gauge. Maybe you will get a recall notice after this first group of bikes are completed.
Old May 27, 2015 | 11:10 AM
b2000s81's Avatar
b2000s81
6th Gear
I just bought a 2015 street glide special and I am having the exact same problem with the clutch. My 2012 street glide had an amazing clutch. The new ones suck.
Old May 27, 2015 | 11:38 AM
joseph07081's Avatar
joseph07081
I have a 15 Ultra Limited Low and I was doing some parking lot drills the other day and I really noticed how much stiffer the clutch pull felt. It made it harder to work the friction zone. I am not on the recall list
Old May 27, 2015 | 12:16 PM
b2000s81's Avatar
b2000s81
6th Gear
I am not on the recall listed either. Any suggestions on modifications or adjustments?
Old May 27, 2015 | 12:18 PM
68 XLCH's Avatar
68 XLCH
Try a few at the dealer to compare, if yours is like those it is normal.
Mine has never been an issue, it is the same after doing the first and only recall for my bike. Seems normal.
Old May 27, 2015 | 12:42 PM
lp's Avatar
lp
Install a weaker clutch spring. HD has them. There are like 5-6 different levels/pressure.
Watch for slipping after.
Old May 27, 2015 | 02:40 PM
skyhawk85u's Avatar
skyhawk85u
The stiff clutch was one major concern I had when I test rode my '14 Limited. I eventually got used to it I guess. After the previous clutch recall, which I had done a couple months ago, the clutch feels like it engages way too far out from the grip. I don't recall if it was like that before, though. Wish I could adjust that like you can with a cable.
Old May 28, 2015 | 05:36 AM
nirschl's Avatar
nirschl
I've only had my new Limited for a week now. Didn't really notice the clutch that much...until there was an accident and traffic backed up in the tunnel. Yep, that sucked just a bit. Never an issue with my 2010 Limited.
On a different topic, the heat management was quite a bit better than my old Limited. I run the Wards Fans and with this new Twin Cooled concept the bike ran much cooler in traffic. It stayed in the 230 range. Very pleased about that.
bradrosewood
Screamin Eagle CVO Models
13
Jun 14, 2015 01:04 PM
RidenChrome
Feb 8, 2011 01:20 PM
johann123
Apr 13, 2010 06:35 AM
jcr
Mar 21, 2010 07:49 PM
Mikeeeeeeeeee
Sep 4, 2006 01:22 AM
