Too stiff!
Old May 1, 2015 | 10:22 AM
bradrosewood's Avatar
bradrosewood
Default Too stiff!
My clutch is way too stiff. 2015 CVO Streetglide. Didn't notice at first cause still riding the new bike high. Took the wife out on the 2010 Ultra and thought man this clutch feels 10 times better!
Any way to adjust this thing (it must be let out at least half way before engaging). Any way to loosen it up?
It's not on the recall list either. Too bad?
Old May 1, 2015 | 11:01 AM
SafetyMan's Avatar
SafetyMan
No adjustment that I'm aware of...
Try these:
Old May 1, 2015 | 12:40 PM
bradrosewood
Default That's a good idea!
Whatcha you got for the three fingers that can still reach by the time it's released?
Old May 1, 2015 | 12:45 PM
dgoodbmw's Avatar
dgoodbmw
Default clutch pull
I agree 100%, there is no reason the pull has to be harder than a cable operated unit. Hydraulic clutches are not new and there is something very wrong with Harley thinking everyone will accept this. I have no solution and a lot of sympathy as i am in the same boat with you.
Old May 1, 2015 | 01:18 PM
mister_hudson's Avatar
mister_hudson
The title of this thread had me thinking this was a Viagra pitch or something...
You'll adapt to it quicker than you think - just have to get used to it I'm sure...
Old May 1, 2015 | 01:32 PM
Gwaxley's Avatar
Gwaxley
After the latest recall my clutch is a little easer or easer to brake over and feels smother the full travel. It seems easer to feather and I actually have been able to hit neutral more times than not.
After the recall before this one or the second one it did not feel any different and seemed to have a little tricky spot before full in gauge. Maybe you will get a recall notice after this first group of bikes are completed.
Old May 1, 2015 | 01:47 PM
Rustrtal's Avatar
Rustrtal
Supposedly the new SE clutch pack makes for an easier pull. Look to the aftermarket for a shorter pull lever.
Old May 1, 2015 | 08:30 PM
THE PEG's Avatar
THE PEG
Clutch pull is firmer but you will get use to it.
Old May 1, 2015 | 08:41 PM
Bikerscum's Avatar
Bikerscum
The CVO's have a different clutch than the standard baggers. The "assist and slip" clutch. My Limited Low has it too. Mine is fine, not too stiff, but the engagement is all the way out at the end of the lever travel. It didn't used to be that way, but I bled the line in an attempt to get more clutch throw & quiet the first gear KLANK. Did neither. I actually prefered the little bit mushy feel it had before.
At the dealer the other day I went down the line of identical (except for color) baggers & tried the clutch. Most all felt about the same, but one felt VERY nice. No reason for it I can come up with.
Old May 1, 2015 | 09:42 PM
p51bombay's Avatar
p51bombay
Only bike recall not completed?
