Boom Box 6.5 question
Last summer a friend & I set about looking into the poor CB performance on our 2014 Limited models. We used a MFJ 269C Antenna Analyzer to look at the factory antenna system. We found the stock CB antenna system was resonant around 25.5 Mhz. The CB band frequency range is 26.965 to 27.405 Mhz. We also found the antenna feed coax was
a) poor quality coax;
b) fitted with a Motorola in-line connector normally used for AM/FM (75 Ohm impedance) antenna systems;
c) that connector is NOT WEATHERPROOF but located behind the seat and has no weather protection or di-electric grease to prevent corrosion;
d) had a ground that was isolated from the main frame of the motorcycle.
Attempting to trim the stock CB antenna (done by removing the plastic tip, then trimming the mast length - shorter length equates to higher resonant frequency) was ineffective. Adding additional grounding wires from the TP mount to the rear sub-frame to the main frame did improve CB performance (per improvement mods included in J&M's CBAU-HU14 kit).
We did find we were able to get the CB antenna system below 2.9:1 by switching from the oe CB antenna to the shorter, top-loaded CB antenna. Further testing after these changes, we were able to extend bike to bike communication range to about 2-1/2 miles under good conditions.
This range improvement was acceptable for our needs, so we ended our experimentation at this point. We are both confident we could further improve the CB performance by completely replacing the poor quality coax with a good quality grade of 8X 50 Ohm impedance coax.
Resultant observed effect is the same.
Appreciated, if not completely understood. I would like to look into improving the usefulness of the CB on my 14 Limited.
I just noticed in the instructions for the antenna that the 2009 and later models use a different antenna than the 2008 and earlier bikes. My antenna only says CB at the bottom. The proper one I mentioned above says 09-CB. So it looks like I'll be stopping by my dealer to get the correct shorty CB antenna.
Now I know with this antenna (08 and earlier), the SWR is 1.5. I hope the correct 09-later shorty antenna keeps it the same or better. Guess I'll find out tomorrow.
UPDATE:
Dealer gave me the proper HD shorty cb antenna. I checked the SWR, and it's at 3.2, which is horrible. It was better with the incorrect cb antenna. I might as well use a string with a soup can on each end since Harley doesn't know how to properly tune the antenna to the cb.
