I bought a 2015 Ultra Limited last month and had the 1K service done this week. The inspection paperwork states that my brake pads are at 50% on the back and 40% on the front. I am not familiar with how thick they were when brand new so......I broke them in gently as well just as the book recommended.
Is this even possible? I can't believe that the brakes on these bikes would need changed every 2000 miles or so, doesn't make sense. Thoughts?
It has to option 2, I hardly ever use the back break. I get that the breaks are linked above 25 MPH but rarely if ever have I used the back break at more than 25 MPH and the break you use when the linking is active gets more of the pressure I believe. I will just watch them from this point forward.
It is correct that the brakes are linked above 20 or 25 mph. But only, if the ABS is activated. This means you have to brake fairly hard, before the ABS comes into play. Only then are both brakes linked. I have to agree with Safetyman. There is no way that you have that much wear and tear on both brakes after 1K. Go to a different dealer.
Are you sure about that? I was under the impression that at speed they're always linked.
I bought a 2015 Ultra Limited last month and had the 1K service done this week. The inspection paperwork states that my break pads are at 50% on the back and 40% on the front. I am not familiar with how thick they were when brand new so......I broke them in gently as well just as the book recommended.
Is this even possible? I can't believe that the breaks on these bikes would need changed every 2000 miles or so, doesn't make sense. Thoughts?
Sounds like Your servicer has a universal answered check list and slipped You the wrong sheet.I replaced My front brakes at 17000 miles.Backs still usable.
Reflex™ Linked Brakes with ABS: All 2014 Harley-DavidsonŽ Touring models are available with the new Reflex™ Linked Brakes with ABS as either Original Equipment or as a Factory-installed option. Reflex™ Linked Brakes combine ABS with electronically linked brakes to dynamically optimize front and rear brake balance. Linked braking is activated when the motorcycle is travelling between 32 and 40 kph. If braking is initiated at slower speeds, the front and rear brakes function independently. When linked braking is active, applying the front, rear or both brake controls will apply braking force to both the front and rear brakes in a proportion determined by the Reflex™ Linked Brakes system to optimize performance. The braking will stay linked as speed drops below the 32 to 40 kph threshold. Reflex™ Linked Brakes incorporates ABS to further help the rider maintain control during braking events, especially those that happen in less-than-optimal conditions. Reflex™ Linked Brakes with ABS are Original Equipment on the 2014 Street GlideŽ Special, Electra GlideŽ Ultra ClassicŽ, and Ultra Limited Harley-DavidsonŽ motorcycle models, and a Factory-installed option on the Road KingŽ and Street GlideŽ models.
**This was from the Harley Canada site, the MPH is 20 to 25.
Break=
separate or cause to separate into pieces as a result of a blow, shock, or strain.
sustain an injury involving the fracture of a bone or bones in a part of the body.
a pause in work or during an activity or event.
Brake=
a device for slowing or stopping a moving vehicle, typically by applying pressure to the wheels.
make a moving vehicle slow down or stop by using a brake
"Reflex Linked Brakes with Anti-lock Braking System
No doubt about it, there are times when you need to haul things down in a hurry. And you dont get to pick those times. Or decide whether or not they occur when youre on a flat, smooth, dry, perfect stretch of pavement. Thats why our touring models feature the Reflex Linked Brakes with ABS. ABS turns a locked-up front wheel or a rear wheel skid into a relic from ridings history. And the front and rear brakes are electronically linked to provide exactly the right amount of brake to each tire no matter what the road condition is. No matter how good you are, this will make you a better rider."
Now this is a copy from the HD-website. Read it carefully and then ask yourself the question, whether ABS must be engaged for the "Reflex" brakes, to work, or not. Without ABS linked brakes wouldn't make any sense, wouldn't they. Besides how would that system work without ABS?
