Tour Pak Conversion
Old Jul 3, 2015 | 08:24 PM
Ahooosier's Avatar
Ahooosier
I just installed the kit myself and the dealer is right in line with time it takes to install it. But that is for my first and only install of it. I can't imagine it taking someone who has done it several times that long to do it. I'm not sure what another poster is referring to about drilling holes for the license plate relocation bracket, as it goes on the same screws/bolts that hold the brake light on, no drilling required. However it is a pretty flimsy lightweight piece of metal. Also as mentioned, wire connectors can and will scratch the fender and moco needs to find a better way to accommodate the wiring connections.
Old Jul 3, 2015 | 08:30 PM
big papa AZ's Avatar
big papa AZ
My wife and I installed the kit in 2 hours, no special tools needed. Now that I did it, I probably would not have bought the lit. I would have bought antenna kit and aftermarket lights. Native Baggers tag relo. The kit makes it no easier to install or remove TP IMHO.
Im still searching for a comfy solo seat. Leaving the puffy seat on defeats the purpose.
[IMG][/IMG]
Old Jul 3, 2015 | 09:03 PM
GalvTexGuy's Avatar
GalvTexGuy
I was referring to this thread - https://www.hdforums.com/forum/new-r...elocation.html
The OP says:
I have the detachable tour pak kit and a detachable sissy bar and luggage rack. When I take off the tour pak and put on the sissy bar and luggage rack, the damn license plate frame is in the f*&*ing way.
One of the responders points to his thread where he relocated the license plate below the brake light. It required drilling holes in the fender to mount it there.
Old Jul 4, 2015 | 06:09 PM
jammerx's Avatar
jammerx
So are there any other alternatives to the turn signals? Can you install the Street glide turn signals? on a 14/15 ultra?
Old Jul 4, 2015 | 06:14 PM
big papa AZ
There are multiple aftermarket LEDs you can install.
Old Jul 4, 2015 | 06:37 PM
p51bombay's Avatar
p51bombay
Yes, but you either have to grind the light bar or swap the fender out for a SG or older Ultra/LTD that has the dimples. I did the latter, they also work as brake light and can be flashed to work as RUN also.
RomeoTango
2014-2024 Touring Models
Jul 3, 2017 07:12 PM
flhrbill
Sep 17, 2013 11:03 PM
2010 ultra man
Sep 5, 2013 03:21 PM
Garemlin
Nov 12, 2012 05:51 PM
Xman1
Aug 8, 2011 11:47 AM
