Will I be able to successfully create a route with Basecamp and import it to the Infotainment GPS? I've used Basecamp for several years with a lot of success with my Zumo. A friend of mine, who has a 2014, imported a route that I created on Basecamp and he had problems with the route. My Zumo was flawless. I've tried using the HD Ride Planner and the system breaks up the route into multiple routes. If I'm using Ride Planner, should I be using Locations or Waypoints? I always use waypoints in Basecamp. The waypoints on HD ride planner don't work very well. I'm planning to trade my 09 for a 2016 and want to get ride of my Zumo if I can successfully master the Infotainment GPS. Any advice? Thanks!
Yep, Basecamp works fine with the Infotainment satnav, I tried Rideplanner when I got my first Rushmore, but I found it to be a complete PITA, now it's Basecamp all the way. You might wanna hold on to the Zumo for a while tho!!
Basecamp is all I use now for the Boom Nav system and it works great. It seems to work the best, IMO.
When you import the gpx file to the bike's Nav system, make sure you only select the single gpx file, do NOT select individual waypoints to import, or anything else... import only the gpx file, the gpx file already contains the waypoints and locations.
Great news! When you stop at a location along your route will the infotainment gps automatically start from where you stopped?
Yes, I've tried Ride Planner and it wasn't great. Switched to Basecamp and have been using it ever since. The only problem that I have is that Basecamp's (Garmin's) maps are much more up-to-date than the Infotainment system. Once in a while, the waypoints don't match up and you may have to skip that waypoint.
I've been looking at Basecamp and have installed it on my computer. Stupid question. Do I need to purchase maps to use it with the Boom Box system?
There's a question, every time I've attempted to use Basecrap it's always wanted my GPS plugged into the computer. How does one do it with the Infotainment system??
I say attempted because I don't think `I've ever actually completed a route with it. Frustrates the hell out of me, WAY more complicated than it needs to be.
Yes, unfortunately you need to purchase and import a map to BaseCamp... However, if you already have a Garmin GPS, the map is already included with your GPS purchase, and you can use the same map for BaseCamp.
