GoPro Anyone???
I am technically challenged, so when it comes to stuff like Protune and the other manual settings on the camera, I don't have a clue.
I used only enough extensions to be able to mount the camera. I tightened them with a screwdriver. The collar is on the rubber thing that it came with.
If you have any suggestions as to what camera settings I can use, I'll try it. Apparently GoPro doesn't use image stabilization yet, so that's not an option, but perhaps other resolutions or something.
Thanks in advance.
http://cbcdn1.gp-static.com/uploads/...G_REVF_WEB.pdf
Page 88 shows how to use it.
I don't know if it is possible to mount on the lower part of the fork, but make sure you mounted the Hog Collar to the top of the fork and the band is completely enclosed in the rubber. Also have the lock-down nut pointing to the outboard side of the fender.
I use 1080P at 60 frames/sec Wide and medium and have very stable videos.
I tighten everthing by hand using the GoPro thumb screws.
