My FOBO works well other than when I went to Colorado. The front tire kept warning of low pressure, but the numbers were right so I ignored it. Back in Louisiana it is again reading correct tire pressure with no warning.
I have the rear on the T valve stem I bought with the sensors. The front is still on the rubber stem, but I will change that too on my next tire change.
I installed a set on a buddies CVO RoadGlide that has the side angled stems too. I checked the clearance and had 1/2" between the caliper and the sensor. He has ridden it several hundred miles without a problem since the install too.
