External vent setup
Old Oct 6, 2015 | 05:58 AM
95ci springer's Avatar
95ci springer
I'll look to see if my softail filter is vented. It was just pulled apart because of a leaking base gasket and the pistons looked like the piston on the bottom. Very clean.
Old Oct 6, 2015 | 08:07 AM
santajim's Avatar
santajim
Originally Posted by DK Custom
In a perfect world the butterflies keep there from being any sucking on the hose...but the butterfly valves are not 100% effecient. There is a small amount of air that does suck back into the engine via the breather system...more at start up and shut down, than while running.
Running a filter at the end of the hose not only guards against the very small chance of anything getting back up into the engine, but the bigger benefit is that it will absorb the oil and other gunk, not leaving drips in the driveway or garage, and not spraying the underside of the bike with oil mist to attract a layer of dirt.
If you are running a filter at the end of the hose and getting oil dripping out of it, it is either-
A cheap filter (or more than 5000 miles since the filter was cleaned)
Too much oil or crankcase pressure
Too low of a viscosity of oil for the temps being ridden in
Worn or defective butterfly valves
Check out a complete selection of External Breather Kits HERE
Do the breather bolts you sell fit under a 14 limited air cleaner cover?
Old Oct 6, 2015 | 10:06 AM
GalvTexGuy's Avatar
GalvTexGuy
If you're going to install the breather kit, you shouldn't need to change the breather bolts on your 14 Limited. I didn't when I installed mine.
Old Oct 6, 2015 | 10:14 AM
santajim's Avatar
santajim
I know but DK sells breather bolts with filters in them and i was wondering if those were replacement bolts
Old Oct 6, 2015 | 10:44 AM
GalvTexGuy's Avatar
GalvTexGuy
I knew that.
Old Oct 6, 2015 | 11:55 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
The Outlaw Breather Bolts are designed to work with a variety of aftermarket air cleaners. They will not work with the stock 14 Ultra Limited air cleaner.
The External Breather System for that bike, with the stock A/C is the Discrete & Flexible Head Breather System, you can see it at this LINK
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Road Star
Touring Parts
Oct 29, 2018 02:36 PM
JohnnyDrama
2014-2024 Touring Models
Nov 7, 2016 02:04 PM
fourburgs
Jun 24, 2015 06:01 PM
harleytq
Oct 13, 2014 12:16 PM
SnailTraX
Sep 2, 2014 05:52 AM
