External vent setup
Old Oct 3, 2015 | 05:15 PM
polbit's Avatar
polbit
Default External vent setup
Do you guys see anything wrong with this set up? It's a Fuel Moto A/C, and some rubber hose with splitter. Routed it down with an open end close to crossover pipe.
Old Oct 3, 2015 | 06:45 PM
14GuineaPig's Avatar
14GuineaPig
I wonder if oil will pool in the low spot of the line from the front cylinder?
Old Oct 3, 2015 | 08:05 PM
RANGER73's Avatar
RANGER73
It should blow out or get sucked back in.
Old Oct 3, 2015 | 08:07 PM
Campy Roadie's Avatar
Campy Roadie
It can't be sucked back in because of one way valves.
bigrobtemp's Avatar
bigrobtemp
I had mine set up like this with the filter. On road trips I would get oil coming out and blowing back and down on the engine. I ended up taking the filter off and using a piece of hose and routing it through the pushrod tubes right to the ground. If I park it after a long ride it will sometimes leave a drip. I can have it running and put my hand under the tube and I get a good amount of pressure out of that hose. I like it better vented on the ground and you cant see it unless your looking for it.
Old Oct 3, 2015 | 08:36 PM
polbit's Avatar
polbit
Ok, good to know, that's how mine is routed.
Thanks everyone!
Old Oct 3, 2015 | 09:05 PM
mstrobes's Avatar
mstrobes
If you are getting oil in the intake wouldn't your little filter get oil soaked?
I have a corvette and a catch can to catch the oil.
So, this is what I did today.
Old Oct 3, 2015 | 09:09 PM
RANGER73's Avatar
RANGER73
Mine doesn't use a oneway valve, air needs to be able to get sucked into the head. On mine anyway. If not it won't run. It's also a 94 carbed EVO. I don't know if that makes a difference.
Old Oct 3, 2015 | 09:17 PM
bigrobtemp's Avatar
bigrobtemp
Im not sure why you would want to catchbthe oil? I just send it inder the bike and the wind takes it as im riding
Old Oct 3, 2015 | 09:30 PM
lp's Avatar
lp
All EVO's use a one way (exit) umbrella valve in the head as well. Not sure what is up with yours. Interesting.
Blocking the breather is always bad no matter the year or engine. The case will pressurize and the engine won't run correctly.
