plug wire caution
Old Oct 4, 2015 | 04:08 PM
Cobra1's Avatar
Cobra1
The plug cap can be bent a little also. I bent mine and the wire no longer touches anything. I just don't know why the moco doesn't get their supplier to change the angle of the plug. Evidently they don't check these forums for good helpful info.
Old Oct 4, 2015 | 04:51 PM
oakmossy's Avatar
oakmossy
good post as a reminder to newer owners. Moco should send out a notification. Who the hell is running moco?
Old Oct 4, 2015 | 06:32 PM
RandyJK's Avatar
RandyJK
Grrr mine is the same damm thing wore half way through the first riding season, what the hell .. I will be off to Harley next week looking for a replacement wires as my back one has some wear on it also but no where near as bad as the front wire..
Old Oct 4, 2015 | 06:48 PM
Cool Inferno's Avatar
Cool Inferno
Same issue with mine and the service department changed it with no questions asked.
BTW I did read somewhere that certain Goldwings have a problem also with some ignition wires rubbing on the tanks and Honda issued a National Safety Recall to fix the problem. Not sure if it was the spark plug wires or some other ignition/electrical wires.
Edit: It wasn't the Goldwing, its the Kawasaki Vulcan 1700
http://motorbikewriter.com/kawasaki-...safety-recall/
Old Oct 4, 2015 | 07:26 PM
Second Wind's Avatar
Second Wind
Never noticed before but I have wear on mine as well.. My '06 Night Train was zip tied behind horn on motor/horn mount from factory. Might look into doing same thing to RG on plug/wire change this winter.
Old Oct 4, 2015 | 07:28 PM
jpooch00's Avatar
jpooch00
Just a guess, but I'd say a bunch of hacks who don't give a fiddler's damn about QC or their customers!
Like I said before, every Rushmore bike that's been built has this problem and future Rushmores will as well, most likely.
Next time you're at a dealership, check every one of them that's on the floor, you'll see I'm right.
Old Oct 4, 2015 | 07:47 PM
IUOE ROB's Avatar
IUOE ROB
I'm guessing from the pic (thanks OP) that the wear spot is about 2 inches down from the cap, does that sound about right? And does everyone's wire wear at the same spot? I've eyeballed mine and it looked OK, tomorrow I'll go out and feel around a bit, might be worn on the back side where you can't see it. Thanks!
Old Oct 4, 2015 | 08:02 PM
RollaMo's Avatar
RollaMo
Can't find any wear on either of mine either.
I've traced each wire from the plug all the way back to the the coil, and no wear marks.
Old Oct 4, 2015 | 08:43 PM
jpooch00's Avatar
jpooch00
The wear point is just above the spark plug boot where the wire goes behind (and contacts) the tank. Very easy to spot if you look in the right place.
Old Oct 4, 2015 | 08:47 PM
CSMHOG's Avatar
CSMHOG
Yep, right about that spot. We've spot checked three rushmores and they ALL had rub spots on the front cylinder plug wire at the spot where it contacts the fuel tank.
