OK. Now I understand what you're looking for. CPT_C is correct. The P&A connector in the fairing is a 2 place Tyco 070 multilock. Identified in the wiring schematics as connector 299.
Edit: Reviewing the Shop manual, Appendix A, I think the connector may actually be a Tyco 040 multilock. The Tyco 40 is described as as either a 2 place or 4 place connector. The Tyco 070 is described as a 3 place, 6 place, or 10 place connector.
Hope this helps.
Correct sir. This provides power when the ignition is on or in accessory mode. There is a Y connector for this available as well.
