Vibrations...
Old Jan 29, 2016 | 11:10 AM
polbit's Avatar
polbit
Default Vibrations...
Hoping somebody can point me in the right direction here.
When I first got my '15 Road King, I also got FP3 tuner, AN Big Sucker A/C and V&H Twin Slash Round slip-ons, and was happy. The upgrade bug hit though, and I bought Drago H-Pipe headers and took it to Ed from Dyno Difference (highly recommended btw!). The bike runs awesome now, great, smooth power and perfect sound, BUT... since I put on the new headers, the bike has started having vibrations. It went from absolutely vibe-free unless in high RPMs to a slight vibration throughout the entire rev band. It feels like before it was fully isolated, now there is metal-to-metal contact. My hands get tingly after a while, and I can feel it in my boots.
I went over the entire length of the pipes and made sure nothing is touching, and that everything is torqued properly. Any ideas what else I can try? It's to a point now where I'm not riding as much, and am ready to go back to my old set up if I can't figure it out... Thanks for any suggestions!
Old Jan 29, 2016 | 11:27 AM
Racin929's Avatar
Racin929
Did you install the spacer betwixed the header and floorboard? You need it.
Old Jan 29, 2016 | 01:40 PM
polbit's Avatar
polbit
Yes I did, wouldn't have fit without it...
Old Jan 29, 2016 | 01:41 PM
RollaMo's Avatar
RollaMo
Go over your install again.
Your header pipe is making contact somewhere, probably around your footboard mounting brackets.
I know V&H gives you a spacer for the Foot Board bracket to keep the pipes from making contact.
Not sure about your, but that is likely where your issue is.
Old Jan 29, 2016 | 02:07 PM
lp's Avatar
lp
Going along with the exhaust system being the issue:
1. loosen all exhaust fasteners including the 4 exhaust to head nuts, the crossover to collector (if you have one), the oil pan mount (if you have one), and the two allens that attach the mid collector mount to the trans AND the big nut under the mid collector mount.
2. start the bike and let it run for a minute.
3. stop the bike, let it cool, and from the front of the bike, start tightening everything back up. Some start from the back, but it probably works either way. I've had good luck starting at the front for whatever reason.
If this works, you'll probably find that your exhaust was preloaded at the mid collector mount.
Old Jan 30, 2016 | 07:14 AM
polbit's Avatar
polbit
Thanks lp, will try it this weekend. The headers were a bit tough to align with the heads when new...
Old Jan 30, 2016 | 08:00 AM
ejwmiller's Avatar
ejwmiller
I just went through the same thing. Put a set of v&h power duals on my 16 sgs and had a vibration throughout the rpm range. Did as previously stated loosened the whole exhaust and went from front to back. Found it was barely touching the floorboard. Fixed that and now it's as smooth as butter. Feels like it did from the factory. I decide to do all this as I was putting on a black timing cover I noticed a rub mark on the heatshields. That's really how I found the place it was touching. Good luck hope you fix your problem. Nothing more annoying than a vibration you know isn't supposed to be there.
Old Feb 12, 2016 | 08:48 AM
polbit's Avatar
polbit
I FINALLY had a moment to work in the bike... Did the prescribed procedure, and it got a little worse actually. I then looked at it again, and noticed one thing of concern - my left slip-on bracket is sitting right against the edge of the mount, not in the middle like it was with stock exhaust. Not sure why I missed it before, but I have a feeling this is probably the cause, since it's basically loaded against the edge with very little rubber gasket. I'm going to try to force it a bit I guess...
Old Feb 12, 2016 | 08:44 PM
polbit's Avatar
polbit
OK, happy ending to this story! I originally used new standard HD exhaust header gaskets. I re-did it using the flat SE gaskets, and either the new gaskets, or just reinstalling everything solved all my vibe issues! Happy camper now
Old Feb 13, 2016 | 07:07 AM
GTK's Avatar
GTK
Looks as if it took a little work, but glad you solved the vib problem.
