Calling all programmers
Old Feb 4, 2016 | 02:07 PM
BigMike's Avatar
BigMike
Did you try and call the dealer to ask them?
Old Feb 4, 2016 | 02:28 PM
Magnut1's Avatar
Magnut1
The local one I called said "will there might be a lot of R&D" So what I am trying to see if there is a forum member that is a service tech at a dealer to check into it. Some service counter people get kind of irritated when you ask them questions they don't know and just want to get your bike in there and a ticket started.
Old Feb 4, 2016 | 08:41 PM
pswomack's Avatar
pswomack
In order to make your new purchase work, you will need a new CVO RK Speedometer unit, here's the part you will need: 70900389 SPEEDOMETER, TACH/MPH,SPUN ALUM (DOMESTIC, CALIFORNIA) $508.00 from Boardtracker HD Online.
Old Feb 5, 2016 | 07:56 AM
Vernal's Avatar
Vernal
Call the HD Tech line 1 800 258 2464 they should know.
Old Feb 5, 2016 | 10:50 AM
BigMike's Avatar
BigMike
HD would make a killing if they added the CVO ignition switch to the P&A catalog.
Old Feb 5, 2016 | 12:30 PM
Magnut1's Avatar
Magnut1
I know, I have been trying to find it and there is a break down but it is called a 'light"
Old Jan 31, 2017 | 06:52 PM
steveodeluxe's Avatar
steveodeluxe
1st Gear
Default 70900389 question
I want to buy this for my 2011 deluxe and it should work, but my question is does it just plug n play or do I need the extra adapter to download the mileage data then hook it up where the existing speedo sits?
Old Jan 31, 2017 | 07:22 PM
steveodeluxe
1st Gear
Sorry if I sent this twice but how does it look to the exam? Is it through a supplied adapter and then plugged into old speedo harness or does it strictly need to just be plugged into speedo harness and it captures the mileage info?
Old Feb 1, 2017 | 09:14 AM
Magnut1's Avatar
Magnut1
I ended up using my original speedo and replaced the center disc with my ignition switch. Since I didn't want to cut the original wire hareness, I ordered the connector from the ignition switch to the bike harness (2 wire) and made my own jumper and plugged it in. As far as the speedo, I would have to order a new speedo that would marry to my BCM after 31 miles or 100 km so I just used mine. I really love the new dash, gives it a different look for sure.
Blvfisc
2014-2024 Touring Models
16
Jul 7, 2017 02:53 PM
khuenefeldt
Mar 31, 2017 01:30 PM
GoGetter5832
67
Apr 22, 2016 07:27 AM
Magnut1
Feb 29, 2016 06:33 PM
Magnut1
Feb 5, 2016 08:58 PM
