Heated Gear question
Old Feb 15, 2016 | 07:37 PM
HOG Hugger's Avatar
HOG Hugger
It would be nice if Harley included the charging pig tail on more models. Gerbing makes a pigtail that can clip right into the charging harness.
I just went through all of this on the 2015 Limited (today) and the battery is hidden under a bunch of stuff. Still working on it.....
Old Feb 16, 2016 | 03:52 PM
MilesOfTexas's Avatar
MilesOfTexas
Originally Posted by Vernal
Am i missing something here? Basemans's right our bikes only came with the standard 50 amp stator and a VR that should keep up with that demand. Checking the specs on the high output, for $490 plus your time to install it, you gain 4 amps output. I think I'll stick with the stock 50 amp.
Yes, the HO is only 4 amps more, however the big difference is the HO one puts out the amps that you need at idle. The stock one doesn't until around 2K rpm. When running a lot of accessories or heated gear, you need the amperage at idle as well, else it can't keep up at idle and may cause it to go bad sooner instead of later. Heck, I can see that when I turn my heated grips up to level 3. At idle my volts drop to just above 12.
matthew6279
Oct 7, 2018 10:03 AM
lazye
Jan 8, 2014 04:54 PM
Dionicio
Dec 5, 2013 12:32 PM
mastery
Nov 8, 2013 05:19 PM
extsieg
Nov 1, 2009 11:39 PM
