FP3 Tuning Parameters
Old Apr 19, 2016 | 07:14 PM
BlackBetty72's Avatar
BlackBetty72
5th Gear
Default FP3 Tuning Parameters
So folks, after waiting and saving, I have upgraded my 2015 RK to slip on Crusher mellow slash-cuts and a high flow AF as well as invested in a FP3 tuner. I flashed the bike with the file recommended by V&H (for the record, the FP3 is the most amazing bit of kit I have ever seen. I work in diesel product development and similar tools run into the thousands of dollars).
Anyway, I have read the posts regarding using the pre-defined maps or starting with a map and then using auto tune. While the debate seems endless, what I am missing is what performance parameters do people recommend to compare to decide whether a defined map is better or worse than an pre-defined one. For example, would the experts out there recommend that you use fuel economy, max engine temp, and torque as the three comparison points between the potential maps to then pick the best.
Just looking to understand how to pick the better of the two options without relying on just seat of the pants experience.
Old Apr 19, 2016 | 09:29 PM
rv7garage's Avatar
rv7garage
Subscribed. I'd like to learn more
Old Apr 20, 2016 | 08:47 AM
hubble's Avatar
hubble
I'd like to learn more about the fp3 also, I'm thinking about getting one.
Old Apr 20, 2016 | 09:06 AM
RG Pilot's Avatar
RG Pilot
The FP3 is a great tool. Easy to use and has lots of great features including speedometer calibration. You can use a canned map which there are many of them available and then go into auto tune to refine it; not required but it's there. You can then save that auto tune and go back to the canned map to see which tune you like the best and then run with it. Auto tune monitors your O2 sensors and will adjust your VE tables accordingly which effectively changes your AFR at each RPM and throttle setting. Once programmed, you can remove the FP3 from the bike or if you leave it in you can view many of the gauges available on your phone.
Old Apr 20, 2016 | 10:37 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Hello, with the mods in our application I would start with the FP3 base map for the Stage 1 air cleaner and V&H Monster Round mufflers. This will be a good starting point.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Apr 20, 2016 | 10:43 AM
! rock103 !'s Avatar
! rock103 !
Glad its working for you. The last 2 out of the three ive had didnt...good luck
Old Apr 20, 2016 | 11:54 AM
BlackBetty72
5th Gear
Jamie - thanks for the response, this is the exact map I used after contacting V&H customer service. Great service, great response, and from the first 100 miles, spot on recommendation.
The FP3 is a powerful piece of internet enabled wizardry that really puts the whole vast set of tuning knowledge from V&H onto your phone and hence onto your bike. Its so simple to use, honestly, my 10 year old could figure it out (hence it took me twice as long).
Either way, my current plan is run the pre-defined map for a few hundred miles and check outputs like engine temp and fuel mileage since I feel these two parameters are the best measure of overall engine tune - engine temp will tell me if the mix is rich/lean for my driving duty cycle and fuel economy will tell me if I have a good match of throttle position to load (not too much, not too little). I will then repeat the process with auto-tune. Luckily I use the bike as my daily transportation much of the year and thus my driving is highly repeatable from day to day.
Let the best map win!
Old Apr 20, 2016 | 12:10 PM
wparente's Avatar
wparente
One thing to be aware of with the FP3 at least for me, during the Auto-Tune segment my mileage went to hell. At first I was disappointed until I figured out that once I burned the finished map to the ECU the mileage went back up above 40mpg. During the Auto-Tune segment ("I think") there is a lot of extra fuel going in to bike to sample the end results with the O2 sensors or I was just riding more aggressively to fill more cells with data!.
Old Apr 20, 2016 | 01:33 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by wparente
...or I was just riding more aggressively to fill more cells with data!.
This.
Old Apr 20, 2016 | 08:44 PM
Blue Tick's Avatar
Blue Tick
I've really been looking at getting an FP3 myself. My problem currently is I can't seem to decide on which header to go with. I have V&H Twin Slash slip ons and have been thinking about changing those as well.
Sorry to hijack!
