I have only used mine about 2-3 times, and I don't think they work. Can't feel the heat. Will check the fuse.
I'm sure you know, but just a heads up. The new heated grips take a while to heat up, change temp, and cool down. The old setup with almost instant heat had a bad habit of destroying the glue and allowing the grip to come loose. They changed in '14.
At least on my '15 Limited Low ( which thanks to the cheap *** MOCO DIDN'T COME WITH HEATED GRIPS, doesn't bother me tho) the grips get way hotter with the engine running, and take a while to heat. Maybe you just need to let them warm up.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Mine are the same...takes awhile to heat up, but damn they get hot. I think they work great and I've turned them on/off at least 100 times. No issues.
What I should have said, they worked last year at the top of Bear Tooth Pass, but this year when I tried them, they didn't seem to work, but it was cold and dreary, and I just couldn't feel any heat, even on full. So now I will try them in my basement, w/o gloves to actually see if they get warm. How hot should they get?
I can't turn them on past 2 hardly, that's where i usually run them when it's cold, they get pretty hot past that
I don't have heated grips as my "low" did not come with them. Would you guys recommend them over heated gloves? I have read that the grips only hear your palm(which honestly I have never got home and yelled "my palms are freezing") where as the gloves heat your whole hand including your fingers. I have no experience with either.
Ha...Two weeks ago I got caught in a frigg'n So.Utah snow storm coming back from the MoCo factory test rides in St. George. The snow was accumulating on I-15, the front of the Limited was PACKED with show and even the ******** were slowing down on the interstate. I had all my heated gear on including gloves. It was VERY nice to have both gloves and grips that day.
Serious miscalculation on my part...not much worries me but my *** was starting to pucker there for a while...but this time of year anything can happen in this country.
