heated grips
that is controlled via the computer?
instead of using side of grip to turn them on/off I would leave them on and use this button to power them on/off and the side of grip could be used to set temp making them last longer?
This is the way I've set it up on my last three bikes. Always at setting 2, and the Acc. button for on/off.
I like not having to mess with the dial at the end of the grip, it seems like it will eventually malfunction.
I have both, I'm at a loss to say which I prefer more...
First off, I hate the gloves. They're warm but they're far too bulky for my taste, and very expensive. A liner ($70-$100) is the better way to go as far as heated wearables, at least in my case. Much more comfortable and work exactly the same as the gloves.
But between grips/liners? Long term comfort id say the liners; but I have no complaints about the grips; they do get hot, and work well in spite of the cooler air on the top of hands, when using the grips alone(but I have apes, and mine are in the wind, that may be a difference)
On really cold 30-40 deg days, using them both together is AWESOME, however. That's the bestest!! If you went with grips, and turn them above "2", you WILL get home and yell, MY PALMS ARE ON FIRE", so there's that...
I've got heated grips and a set of heated gloves for when I ride my sport bike. The gloves do warm your entire hand but they are a tad bit bulky and you have to remember to bring them in order to be effective..... Out & about on a nice sunny day you may not choose to wear the heated gloves but as the sun fades and the temperatures drop an hour or 2 from home your gloves will do you no good sitting on the shelf. However the heated grips will always be there when you need them
There is good news about the HD stock heated grips, and bad news for the HD P&A heated grips.
